cam caps aarrrggghhh
Old Mar 21, 2007 | 08:43 PM
scottysnewsaff's Avatar
scottysnewsaff
Default cam caps aarrrggghhh
whats the crack with cam caps do you need them with that exact head or can you use others?? or can you get them machined??#
cheeRS
Old Mar 22, 2007 | 08:49 PM
jcrsturbo's Avatar
jcrsturbo
its best to use them with the same head and in the same order so that they wear evanly with cam n head. i dont think you can get them machined itha otherwise theyd b too big
Old Mar 23, 2007 | 01:00 PM
They can be machined by milling the base then line boring but bot cheap.
Old Mar 23, 2007 | 01:43 PM
sailorbob's Avatar
sailorbob
You can get the head and caps remachined to bring them back to spec, expect to pay about Ł200 ex VAT on a DOHC 4 cylinder.
Old Mar 23, 2007 | 07:06 PM
scottysnewsaff
all sorted now they fit and running fine and free
Old Mar 24, 2007 | 03:38 AM
2001ode's Avatar
2001ode
Hi,
No need machined if you can check free rotation of your camshaft, before.
In exemple, if you have problem with one cap, fit your camshaft without your defective cap, and test the free rotation without and with the new cap.
If problem, you can overdrill the cap (ie 6.4 mm. instead 6.1 mm.) and refit. Cap will be exactly in good position on camshaft. Tighten.
Regards
Claude
Old Mar 24, 2007 | 06:45 PM
col cos1's Avatar
col cos1
i couldnt find one but had spare head so changed over the 1 that was missing,i was lucky it was ok
Old Mar 24, 2007 | 10:29 PM
jcrsturbo's Avatar
jcrsturbo
oh yeahh ddnt think of doin that, wel u learn somin new evryday
20/20 vision
Sep 28, 2015 03:03 PM
