Coil pack on efi cvh
Old Mar 21, 2007 | 06:03 PM
base190380's Avatar
base190380
Default Coil pack on efi cvh
Hi I have a fiesta rsturbo engine im fiting into 1.6 efi orion. the coil packl that came with engine was cracked so i cant use it and i was going to use the 1.6 efi one, but ive noticed that part numbers are different.
rs turbo fiesta one is 88sf-12029 a1a with red label and standard one is 88sf-12029 a2a with white label.
Any ideas if i can use it and what the difference where?
Old Mar 21, 2007 | 07:28 PM
Rick's Avatar
Rick
I don't know the difference, but they are all interchangeable. Mine has no longer got a label on. It could be that they just changed the partno as time went by.
Old Mar 21, 2007 | 08:52 PM
base190380's Avatar
base190380
thanks for that advice, anyone else have any ideas????
Old Mar 21, 2007 | 09:42 PM
jcrsturbo's Avatar
jcrsturbo
i recon it should be ok, if its too powerfull its only gona burn out the plugs or leads. im not saying go n put it on but if it was me id use it
Old Mar 21, 2007 | 11:29 PM
SafeChav's Avatar
SafeChav
They are all the same.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
