boosting
Old Mar 19, 2007 | 10:09 PM
paulturbo's Avatar
paulturbo
Default boosting
if your car is running low on petorl would this cause it not to boost as i have just filled it up and its going like mad as i have only had the car for a few weeks i have been putting in a fiver or a tenner. whan i brought the car the lad said the petorl guage did not work and putting five or ten pound in is not going to take it out the red antway as it was just not moving at all but i have just filled the tank and its boosing a lot better now but the turbo guage is still not moving much at all only going to 0.4 can anyone help me please
Old Mar 20, 2007 | 02:04 PM
scottysnewsaff's Avatar
scottysnewsaff
depends what car you have and what fuel pump? if it is an uprated one mine and a few of my mates have uprated fuel pumps and wont let you boot it with less than 1/4 of a tank they still boost but dets and backfires so would advise keeping the petrol topped above that just a suggestion probably not what the problem is but its worth a try
Old Mar 20, 2007 | 02:14 PM
paulturbo's Avatar
paulturbo
its a esort rs turbo mate
Old Mar 20, 2007 | 04:27 PM
scottysnewsaff
is it a standard or uprated fuel pump mate?
Old Mar 20, 2007 | 04:57 PM
SafeChav's Avatar
SafeChav
Shouldnt make that much difference, if its a low fuel issue you will hear the pump whine as air enters.
Old Mar 21, 2007 | 05:32 PM
choppa's Avatar
choppa
the quickest simplest answer mate is that its possible it never gets filled up. this will cause the fuel tank to deteriorate quicker and little bits of crap might be getting caught in the filter. the tank one! however when you fill it right up the filter is probably completely immersed in fuel so it has more little holes or a cleaner section of filter material to suck the fuel through.
Old Mar 22, 2007 | 09:32 PM
jcrsturbo's Avatar
jcrsturbo
£10 punds will deff bring it out of the red. i put £20 in n it takes it nearly to the top in my rst
Old Mar 22, 2007 | 09:36 PM
SafeChav's Avatar
SafeChav
The gauges are more accurate in the lower half of the section, which is understadable!
£10 usually reads about half a tank but obviously is just less than a quarter.......being a 47L tank!
Is the car consistently better with more fuel in?
Old Mar 22, 2007 | 10:24 PM
jcrsturbo's Avatar
jcrsturbo
yeh, i mean nealy to the top of the guage not nearly to the top of the tank. also, try using ultimate fuel if u dnt already, mine doesnt like normal petrol atall. n if the boost guage isnt working proply check the pipe goin 2 it make sure it isnt split or anything
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
