Escort Cosworth Lambda Sensor Part Number
Old Mar 18, 2007 | 11:03 AM
byrrul's Avatar
byrrul
Default Escort Cosworth Lambda Sensor Part Number
Hello, does anyone have a part number for a Lambda/Oxygen sensor on a 1993 big turbo Escort Cosworth. The genuine Ford part number/finis code would be good or the Bosch part number, actually any part numbers at all would be good!
Mine currently has a NTK D5F (and is stuffed) but I can't find any reference to this at all.
Also if I was to fit a universal sensor, do these cars need a Titanium or Zirconium sensor?
Thanks in advance,
Mark.
Old Mar 18, 2007 | 11:05 AM
KSA-Cossie's Avatar
KSA-Cossie
My spare one is in at work mark can get you the numbers off that one later if it's any good ?
Old Mar 18, 2007 | 11:07 AM
byrrul's Avatar
byrrul
Yes that would be great, thanks very much and thanks for such a quick reply!
Cheers,
Mark.
Old Mar 18, 2007 | 11:19 AM
KSA-Cossie's Avatar
KSA-Cossie
No probs m8.
Old Mar 18, 2007 | 12:56 PM
2001ode's Avatar
2001ode
Hi,
Escort Lambda sensor ref is : NTK D5F (Weber Marelli)
Regards
Claude
Old Mar 19, 2007 | 05:21 AM
byrrul's Avatar
byrrul
Mine is the same as the one above, thank you Claude for the photos.
I spoke to NGK head office in Australia and they were able to give me some possible alternatives, OZA23-D2 (Ford Falcon) or OZA2F-2B (Holden Commodore) depending on thread size.
He also said that the Titania ones are more resistant to unleaded fuel, so on next days off I'll compare them.
Cheers,
Mark.
I found some more info on oxygen sensors here:
http://members.pcug.org.au/~jdeakins/facts.html
It relates primarily to Nissans although at the bottom of the page it has usefull information on naming conventions etc.
Old Jul 4, 2007 | 01:24 PM
JanDK's Avatar
JanDK
Just checking.. tread size is 12mm isnt it??
Old Jul 5, 2007 | 10:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
I can do you a genuine one at £80 delivered if it helps at all pal?
Old Jul 5, 2007 | 06:21 PM
JanDK's Avatar
JanDK
Hi again Stewart ( in this thread )
VERY kind of you to offer this.. But I already ordered on.. not genuine but properly ok!
I will remember that next time.. and a next will come
Old Jul 6, 2007 | 09:30 AM
Your welcome mate. Im sure it will be fine.
Vincereese
Jun 1, 2023 09:14 AM
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Old ford
Jul 31, 2015 06:50 AM
