knocking coming from engine as revs are increased. backfired
Old Apr 20, 2007 | 12:13 PM
  #41
havv's Avatar
havv
really? i thought a rebuilt engine would help the figure stay where it is, or is supposed to be. i really dont know what the power is, just from work of mouth from the previous owner. Mods done are;
~T3 stage 3 hybrid BB turbo
~ - 31 Actuator
~Kent CVH25 cam
~Piper cams vernier pulley
~Stage 3 port and polish head
~Stage 3 Ecu with hearts and diamonds chip
~Denso iridium Spark plugs
~Full S/S scorpion exhaust system 3" from manifold
~Scorpion 4" rolled back box to go with system above
~Samco boost hoses and inter cooler pipes
~Chrome Rocker cover
~Polished charge carrier
~5th injector on charge carrier
~k&n Air filter
Old Apr 20, 2007 | 12:58 PM
  #42
Phil79's Avatar
Phil79
sounds like a decent set up. Lets just hope the garage that are sorting it are not the same kind of wankers as the last garage.
Deffo get it set up though mate, there must be an RS tuner local to you
Old Apr 20, 2007 | 01:14 PM
  #43
SafeChav's Avatar
SafeChav
havv what i mean is, you've bought this car second hand and it hasnt been all its cracked up to be, so based on that i would take the figures you were told with a pinch of salt aswell, you may get a pleasant surprise but the harsh reality is people will tell you anything to sell a car
Old Apr 20, 2007 | 01:46 PM
  #44
havv's Avatar
havv
yea your right safechav. thats my worry. i have to get it done anyway, so will let you all know the result soon. So far however, all the mods were there. obviosuly i cant see if its got a stage 3 ecu chip, but everything else seems to be as stated.
Will let you know in a couple of weeks!
Old Apr 20, 2007 | 08:35 PM
  #45
DROPTOP's Avatar
DROPTOP
200 at 8 psi ??? optimistic i'd have thought .
re making a profit on it rebuilding old fords never makes anyone profit lol be prepared to cry when it comes time to sell like many others before you
Old Apr 21, 2007 | 11:14 AM
  #46
havv's Avatar
havv
yea i wish i knew more about fords when i bought the car. 200bhp at 8psi is kinda ridiculous, even though the car felt as fast as my 2.2vtec prelude :S, which has a proven 210bhp at crank.
as soon as its run in, im going to find out which is faster!
Also im sure there will be someone around looking for a car (hopefully some1 who doesnt really know to much about fords, i know, im not going to sell on this site lol) which is still resistered as a 1.3 for tax and insurance purposes but is fast enough to blow away all their mates. you know how it is when young drivers want to start off for their first car.
Old Apr 22, 2007 | 07:55 AM
  #47
DROPTOP's Avatar
DROPTOP
i wouldnt spend too much on it unless youre keeping it long term . end of the day its just a 1.3 and people looking to buy can be funny about things not having the rs badge
Old May 18, 2007 | 08:03 PM
  #48
havv's Avatar
havv
right got the car back... nearly!
they say tomrrow, at the moment there is too much smoke coming out the back because of the oil used for running in the engine. i need to get the car tested on set up.. any suggestions... i live in surrey
Old May 18, 2007 | 08:36 PM
  #49
SafeChav's Avatar
SafeChav
shoudn't really be smoking that bad if at all tbh
Old May 19, 2007 | 10:15 PM
  #50
havv's Avatar
havv
o.... they say its because of the running in oil, the pistons are making their new holes etc. aparently it needs 100miles or so then 10w40 can go in and aparntly itl be all good.
the propblem atm is that the ignition is very tempremental, sometimes it wont even tick over and then sometimes it just starts with a bit of help with the throttle. any idea what this is? cheers mate youve been a lot of help
Old May 20, 2007 | 09:39 PM
  #51
SafeChav's Avatar
SafeChav
What oil are they running in it
Could be an ignition fault, sounds more like an air leak to me though.
Old May 20, 2007 | 09:46 PM
  #52
havv's Avatar
havv
not sure il find out the oil their running, but the oil is very very very thin. nearly like thick water...
sorted out igniition thanks though!
should thinner oil mean smoke? or thicker?
Old May 20, 2007 | 09:48 PM
  #53
havv's Avatar
havv
o and cheked the charge carrier, there was a little oil in there, its a slight leak from the turbo gasket, calened it out, started the car and there was still al ot of smoke. after i chekd the carrier and no oil was in there.. so i dont know... maybe their right? ever heard of this before?
  #54
SafeChav's Avatar
SafeChav
thin oils will slip past the piston rings, but to be honest they run on very thin oil anyway its a turbo motor after all
Old May 20, 2007 | 10:14 PM
  #55
havv's Avatar
havv
yea thats what i was just thinking. thin as 0w40? i need to find out how thin running in oil and ill let you know.
on a seperate note, would you know any cheap good tuning companies with rolling roads etc.. and.. i cant seem to find the jacking points on the car? any idea?
Old May 20, 2007 | 11:33 PM
  #56
SafeChav's Avatar
SafeChav
Mine had 0w40, or possibly 5w40 on a completely re-furbed engine and didn't smoke............
Old May 21, 2007 | 12:31 PM
  #57
Phil79's Avatar
Phil79
If the smoke is white, it's probably due to the de-coking. if it carries on, and it's blue, looks like you will need a new turbo, or someone has got their pistons/rings sizes incorrect
Hope it gets sorted
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
IAN RS2k
Aug 18, 2015 07:51 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
taylora1409
Aug 12, 2015 12:06 PM
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
