Safe Boost Levels
Old Mar 12, 2007 | 09:11 PM
pacman's Avatar
pacman
Default Safe Boost Levels
Got a problem hope somebody can help?
Currently running 2wd sapphire cos, 7.4:1 compression, ported head, BD10's, ARP stud and nut kit, Turbo Technics stage 3 T34 with .55 housing, 34 Actuator, pace RS500 spec intercooler and Grey injectors.
Previously after live map running 2 bar but since been told over speeding and damaging turbo.
What is the safe boost limit to run on this specification as i have dropped it to 24 PSI?
Old Mar 12, 2007 | 09:35 PM
rapidcossie's Avatar
rapidcossie
i ran and held 22 on this turbo...
no reason my it shouldnt do 2 bar tho
best speak to turbo technics
Old Mar 12, 2007 | 09:55 PM
pacman's Avatar
pacman
thanks for the advice, will call them and see what they say.
i also have the option of a t34 roller bearing turbo on a .63 housing which i'm trying to find the identity of, led to believe its an owen developments unit but has no numbers they can match.is there any way to tell if it is roller bearing just by looking or would i have to fit it and see.
i'm certainly interested in this unit if it is what it says
Old Mar 13, 2007 | 07:22 AM
T34 will run 2 bar all day long, same as std T3 will do stage one, it will just shorten life of std T3 as it only has 270 degree bearing.
Old Mar 13, 2007 | 04:31 PM
pacman's Avatar
pacman
seems like i may be being a bit cautious then.
appreciate the help.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
