boosting rs turbo
Old Mar 10, 2007 | 08:41 PM
paulturbo's Avatar
paulturbo
Default boosting rs turbo
hi all i have a escort rs turbo and its my first one do not know much about them but its not boosting much at all i have just put a new turbo on it my last one did not have the water going throw the turbo but this one has i may of fitted it wrong ie actuator pipe where does that go to i am in a mess so could someone help please thanks paul
Old Mar 10, 2007 | 09:12 PM
davidreader5's Avatar
davidreader5
Default boost problem
Hi,
The wastegate actuator pipe goes on the amal valve, if you look closely
at the valve, if still fitted, you will see where the pipes go on,, letters ie R-C- & W, W IS FOR wategate (actuator ) pipe, the other two letters stand for compressor & relief, adjust the rod of the actuator until you can see approx half of the hole of the rod over the wastegate linkcage with the wastegate closed, so it just slips on with a little pull of pressure on the rod, you have to have some pressure to make sure the wategate is shut, otherwise you will have boost problems,
Dave R.
Old Mar 10, 2007 | 11:19 PM
paulturbo's Avatar
paulturbo
my car ant got a amal valve mate its been took of
Old Mar 11, 2007 | 01:11 PM
davidreader5
Hi,
If no amal valve fitted, you probably have a bleed valve device, a pipe from the compressor of the turbo housing,
to the bleed valve then to the actuator,
Regards Dave R.
Old Mar 11, 2007 | 10:26 PM
paulturbo's Avatar
paulturbo
yes i have mate
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
gchristophi
Aug 31, 2015 10:36 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Escortdriver1
Jul 31, 2015 02:36 PM
