MK5 Escort RS 2000 tapping noise.
Old Mar 6, 2007 | 02:39 PM
originalcabbie's Avatar
originalcabbie
Default MK5 Escort RS 2000 tapping noise.
Hi,
I have a mk5 escort rs 2000 and I have a strange problem. After a long drive I get a loud tapping noise from the engine. I have checked for the noise and can only find it near the fron of the engine, alternator etc.
I have checked the alternator and it is charging fine but I am getting the battery light on without tapping!!!
I also have a severe steering problem. All parts are new except second hand steering rack (power steering) do you have to bleed the rack? as everytime i get it tracked about 200 yards down the road it goes funny and pulls all over the place.
The whole front end dont feel safe!
anybody gor any ideas?
Power steering pump maybe?
Old Mar 10, 2007 | 01:17 PM
16vzetec's Avatar
16vzetec
the mk5 rs2000 has a hidious suspension setup at the front.
it runs absolutely no caster so the shock sits bolt upright where it should really sit backwards.
the mk6 was made alot better by the suspension turrets actually being moved back about an inch or more.
if you run anything appart from standard mk5 wheels you can get twitchyness from them.
answer is to try a give the car caster, maybe some adjustable topmounts to set the shock back a bit.
as for tapping i aint sure, tappets?
pm me for more info on the handling
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
3dr cossie
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
