zvh problem
Old Mar 2, 2007 | 08:19 AM
b_kennedy's Avatar
b_kennedy
Default zvh problem
Noticed a slight tapping coming from the engine. Engine is relataivley a new rebuild. I changed the cam and lifters and it seemed so much better, however....
Cruising back on m4 last night and i casually went to overtake a lorry. Didnt drop down a gear, just slightly boosted to about 3psi. Hardly any acceleration at all and I could hear tap tap tap tap very very loudly. Any ideas????
Please dont say rebuild unless u have too
Old Mar 2, 2007 | 08:36 PM
gup's Avatar
gup
did you change the oil when you fitted the cam fella also what grade oil are you running
are you getting good oil pressure to the head also
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
