FSE Query
Old Feb 26, 2007 | 05:15 PM
mcbernie's Avatar
mcbernie
Default FSE Query
when fitting the small pipe off the top of the FSE, do u connect it to the inlet manifold side (i.e boost/vac) or after the throttle butterfly (i.e boost only)
Ive had it on the inlet manifold side
is this correct?????
Thanks
Old Feb 27, 2007 | 09:12 AM
jon@work's Avatar
jon@work
There was a post ages ago (and I mean years) that said that FSE fuel pressure regulators are not recommended for use on cossies. I don't know what sort of power you're running, but it may be worthwhile getting a standard regulator. The vacuum hose should connect to one of the take-offs in the plenum.
Old Feb 27, 2007 | 11:54 AM
SafeChav's Avatar
SafeChav
You want it after the throttle plate.
But as has been already said, the standard Weber FPR is much better than the FSE..............
Dave McB
Oct 5, 2005 01:10 PM
streetdragster
Aug 23, 2005 04:41 PM
ImaRacing 700
Jul 31, 2005 08:10 PM
Paulie Wheelnuts
Mar 27, 2005 07:42 PM
