escort rs turbo prob
Old Feb 25, 2007 | 02:06 PM
rick25's Avatar
rick25
Default escort rs turbo prob
i have no dash lights and no rear lights.any ideas i havnt a clue on car electrics.
Old Feb 25, 2007 | 02:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
Light switch maybe fucked
Old Feb 25, 2007 | 02:21 PM
rick25's Avatar
rick25
im getting headlights.
Old Feb 25, 2007 | 02:32 PM
antony215's Avatar
antony215
Escort Rs Turbo
You can just get headlights if the switch is gone if you have a spare one swap them and see what happens.
Old Feb 25, 2007 | 02:44 PM
rick25's Avatar
rick25
ok mate will give it ago
Old Feb 25, 2007 | 03:10 PM
SafeChav's Avatar
SafeChav
Have u got front side lights?
If not the fuses are more than likely gone in the fuse box! Theres one for each side.
Old Feb 25, 2007 | 03:52 PM
eliters1's Avatar
eliters1
theres a fuse that does left s lights and dash ones,if not check relay but fuse more likely.
Old Feb 26, 2007 | 03:05 PM
rick25's Avatar
rick25
ill give it a try thanks for the advice.
Old Feb 26, 2007 | 03:28 PM
SafeChav's Avatar
SafeChav
Keep us posted
Old Feb 27, 2007 | 11:10 AM
b_kennedy's Avatar
b_kennedy
SafeChav
you know im the man for this job LOL
rick25
I had same problem fella. It was to do with the earth. The rear lights are linkedto dashlight earth fella. Any questions ask CHAV. He's the bo**ox
Old Feb 27, 2007 | 11:49 AM
SafeChav's Avatar
SafeChav
Originally Posted by b_kennedy
SafeChav
Yea...........if you want you car to set on fire Ben is your man
Of if your steering wheel fails the MOT for excessive play (solved by lambert & butler )
Old Feb 27, 2007 | 11:57 AM
b_kennedy's Avatar
b_kennedy
[quote="SafeChav"]
SafeChav
Or if your steering wheel fails the MOT for excessive play (solved by lambert & butler )
dont take the piss!!!! I cant afford Lambert. It was Mayfair
Old Feb 27, 2007 | 12:37 PM
SafeChav's Avatar
SafeChav
[quote="b_kennedy"]
SafeChav
You tight cunt
Old Feb 28, 2007 | 04:14 PM
rick25's Avatar
rick25
checked fuses they are all ok.were can i get the relays from and which one is it.if that dosnt work ill look for bad earth or change the switch.
Old Feb 28, 2007 | 04:21 PM
SafeChav's Avatar
SafeChav
Pretty sure the relays dont operate the sidelights. But have a play with the relays in the fuse box, remove them all and check for corrosion.
If not i'd say change the stalk.
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
