S1 turbo not running
Old Feb 25, 2007 | 10:33 AM
originalcabbie's Avatar
originalcabbie
Default S1 turbo not running
Did some welding on the S1, disconnected the battery , ecu's etc to make safe. Tried to start the car after nothing tries to fire but wont any ideas?
Old Feb 25, 2007 | 10:51 AM
eliters1's Avatar
eliters1
i had this before check the fuse box for a blown one as there is one that causes this.
failing that remove air filter and hold flap down a bt then try it.
Old Feb 25, 2007 | 11:42 AM
SafeChav's Avatar
SafeChav
Back to basics again im afraid. Whats missing from the equation, fuel or spark?
Old Feb 25, 2007 | 12:07 PM
originalcabbie
Its cool sorted it all. I dunno why I unplugged all my vacuum hoses except the one to the ecu and fired up first time, and changed the plugs!
Oh well what fun this will bring. Anyone know a good welder in the midlands to do my floor pans???
Cheers lads
Old Feb 25, 2007 | 12:09 PM
SafeChav's Avatar
SafeChav
Disconnecting the vacuum hoses shouldnt of made a difference?
I thought you said you disconnected the battery to do the welding?
Old Feb 25, 2007 | 06:01 PM
originalcabbie
yeah disconnected the battery. The vaccum hoses are for the 5th injector and the boost guage. It has been crap starting the last few times so I dosconected all that could be leaking and just put in the ecu feed.
I call it proccess of elimination.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
