Annoying locking problem
Old Feb 24, 2007 | 12:28 AM
Chris_505's Avatar
Chris_505
Default Annoying locking problem
Escort Mk4. Just started doing this and it's constant!
Whenever either door is open, the central locking is repeatedly switching from locked to unlocked to locked etc. Whine-click-whine-click-whine-click...
When both doors are shut it stops and they are then permanently locked. I pull the inner handle to get out and it opens fine but whine-click-whine-click... til i shut it. This also means that when getting in from the outside I have to turn the key in the lock and open it quick while it's momentarity in its unlocked state
What's happened and how do I sort it?
Thanks, Chris
Old Feb 24, 2007 | 11:52 AM
SafeChav's Avatar
SafeChav
Check the latches are screwed tighly in the doors to start with!
If not its probably a motor knackered or a wiring fault.
Old Feb 27, 2007 | 12:15 PM
cossie04's Avatar
cossie04
I`d agree with Safechav, but to find out, just unplug each solonoid at a time (including the one in the boot), And then try it. When it works, you`ve found your problam....
Hope that helps...
Old Feb 27, 2007 | 12:40 PM
SafeChav's Avatar
SafeChav
It can only ever be a fault on the front 2 doors as they have internal switches aswell (one of the few cars around that time with central locking that operates from both sides)
Rear doors and tailgates shouldnt be linked to locking/unlocking issues
Old Feb 27, 2007 | 03:52 PM
slider's Avatar
slider
as has already been said its a slow motor probably in the passenger door, try unplugging that motor if it cures the problem cut the brown wire at that motor, that will mean that you wont be able to unlock all the doors from that side but it will still unlock them all from the drivers door and it will stop the annoying stuff until you can get a new motor (if you can be bothered)
Old Feb 27, 2007 | 03:56 PM
SafeChav's Avatar
SafeChav
Fuck cutting wires what a bodge!
As ive said further up most of the time a bit of oil sorts things out, no need to be chopping wires!!!
And if you cut the brown wire the passenger door it wont lock with the central locking at all.......
Old Mar 1, 2007 | 06:32 PM
Chris_505's Avatar
Chris_505
hello again, had no internet for last few days...
it turned out to be the driver's side motor which i've simply unhooked from the mechanism. as a result i now have no central locking, but to be honest i'm not really bothered. it's less to go wrong again plus i'll easy get used to letting passengers in. will maybe try a bit of oil or a fresh motor at some point but i'm happy for now!
been a huge help as always, thanks a lot
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Fudgey
Sep 17, 2015 01:06 PM
tib2220
Sep 14, 2015 12:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
