Rebuilding cvh
Old Jan 4, 2004 | 08:25 PM
Default Rebuilding cvh
Hey
Ok i've done it, I have bough another engine. Done 180,000km, and has a funny sound from the cam (have been told haven't heard it myself..)
So I want to rebuild it into something than can take 200 bhp, maybe more. I want to keep it 1,6 cvh
What would you recommend I use for the rebuild? What should be done?
Old Jan 5, 2004 | 05:36 PM
a cam kit like the piper 285T or the kent cvh34,
new piston rings,gasket set, water pump,oil pump,vernier pulley, cam belt,
heavy duty bearing shells, conrod bolts,flywheel bolts,and some more and maybe new pistons, rockers , valves and valveseats.
I guess the crankshaft needs to be machined at that amount of mileage.
u also need to have the cilinders getting honed and maybe rebored.
not to forget the 'special' tools and other bits.
its not possible to say what needs to be done to any particular engine. its best to get hold of some education like 'rebuilding ford's cvh engine' from Haynes.. hope this helps
Old Jan 7, 2004 | 07:50 AM
Hey
Well It all started with me getting that book hmm you recon I can get all those things from burton power.. and do I need an Engine stand?
Old Jan 7, 2004 | 05:19 PM
yeh all the parts you should beable to get from burton and a engine stand would be very handy a hybrid turbo might help you to for the 200bhp you want and low comp pistons and chip it this will bring ur compresion ratio down and allow you to run more boost i think its bout 8/9psi standard.
Old Jan 7, 2004 | 09:37 PM
is it complicated to rebuild one of these?? ive always wanted to do it but jus got put off wiv things like the timings!!!
Old Jan 8, 2004 | 02:15 PM
Hey
yeah I'm into all the things about chipping athe ecu, but I was wondering if you would need a spacer plate or some low comp pistons? what would be the best thing?
I'm deffo gonna get an engine stand
Old Jan 8, 2004 | 09:40 PM
its not hard to do a rebuild, the engine has markings on it for the timing settings all you have to do is line markings up buy a haynes manual it has all timing marks shown in pictures and it takes you thru step by step, it also has all the torque settings for parts like the head bolts, main bearings etc etc wich you will need, also mite need an engine jack if you wana take out the complete engine, i no on the fiesta turbo to get the engine block out the gearbox comes out with it as 1 piece the low comp pistons are a deffo (but not cheap) it will able you to run higher boost and not to sure bout the spacer plate to be honest, the main thing is to take your time or if you can buy a complete engine 2nd hand and do all the work to it then fit it and break your old engine and sell it or and you should maybe look into uprating your brakes to, 200bhp anit cheap but done rite it will be worth every penny hope this has helped a bit more
Old Jan 8, 2004 | 09:48 PM
Old Jan 12, 2004 | 08:54 PM
Hi mate check on ebay ive got a set of brand new heavy duty bearings bought from burton power on there for sale,i bought all parts to rebuild mine but got offerd a mint engine instead sold all other parts though.
Old Jan 13, 2004 | 09:49 AM
frstboy, thnx, but I really wonder if you could "do" with a spacer plate.. although it seems to be the cheap option
Im getting an engine stand and I'll start to take it apart... can't wait
turbo.jon, I'll take a look a it, thanx
Old Jan 13, 2004 | 06:49 PM
ive decided to stick to standard wheels for now but spacers do seem to be the easy option.
mk3ste
Oct 17, 2021 10:09 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
