Changing from std coil to grp A on cossie
Old Sep 8, 2004 | 08:14 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Changing from std coil to grp A on cossie
Just got a group A coil for my cossie, but the connections are not the same as the original one.
Does it matter which wire (green and black) goes where ? Or, are they interchangeable ?
the group a coil viewed from above looks like this, which connector should I plug the green and black wires too ?
O <- coil lead to dizzy
(the = are spade connectors).
Thanks in advance.
Greg
Old Sep 8, 2004 | 08:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
The green goes to teh one marked as negative.
Old Sep 8, 2004 | 08:32 AM
frog's Avatar
frog
Cheers stu, much appreciated
Old Sep 8, 2004 | 09:12 AM
Daveyraveygravy's Avatar
Daveyraveygravy
Does it make a difference then fellas? I got told it's just a gimmick
Old Sep 8, 2004 | 09:49 AM
frog's Avatar
frog
Dunno m8, had to change mine and the grp A was only a few quid extra so I thought why not.
I suppose it can help resale for those folks (like me) who don't really know if there is a real difference. I mean the car's got rally bits on
Old Sep 8, 2004 | 12:48 PM
wimwerf's Avatar
wimwerf
no its not a gimmick. it really works. i have no misfires anymore.
cheers
Old Sep 8, 2004 | 10:06 PM
Daveyraveygravy
Ok cool, i'll go get one then eh!
Old Sep 8, 2004 | 10:10 PM
frog's Avatar
frog
They sure work - check this out ! No more mis-fires
https://passionford.com/forum/viewto...820&highlight=
On a more serious note, it didn't cure the misfire on mine, but I never got a chance to try a slightly smaller plug gap due to the above happening before I got home
Old Sep 8, 2004 | 11:21 PM
Daveyraveygravy
NOOOOOOOOOOOOOOOOOOOOOOO!
Damn i am SO sorry to hear that, i hope everything works out ok for you
Old Sep 9, 2004 | 07:55 AM
frog's Avatar
frog
Yeah, me too. Should have said that the new coil and leads DID make a difference, I had the same misfire with the new with a .65mm plug gap whereas I had to gap the plugs to .5mm for the car to be more or less driveable with my old leads and coil.
Whether the improvement is down to new leads and coil, or, the grp A coil alone I am not sure, and I certainly can't swap new for old again to find out at the moment (see above post) !
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
cossirob
Sep 3, 2015 09:17 PM
cameron2
Aug 25, 2015 07:18 AM
