Water rising in header tank
Old 03-02-2007, 04:49 PM
  #41
SafeChav
SafeChav's Avatar
Originally Posted by SafeChav
Well if you let it get hot and rev it up the water will rise, by keeping the cap on you pressurise the system.
Originally Posted by ram
sympom is still there!
the water rises in the header tank even when the lid is on tight??!!
Old 03-02-2007, 07:24 PM
  #42
rs_seg
rs_seg's Avatar
that happened to my fiesta rs turbo it was just an air lock.
try bleeding the system by runing the engine with the header tank open and the heating on hot .when the heating get hot the system should be bled.
Old 05-02-2007, 03:21 AM
  #43
ram
Has a large member
ram's Avatar
im back after my weekend away, so guess i better get back to this...
tabetha as safechav has said, im talking about water rising to the top in a matter of seconds when i idle the engine at around 3000rpm. with the cap on.
what is the PCV system? as i will be checking as much as i can tommorow for blocks ad i might as well start with the most likely ones.
rs_seg thats what i was hoping. but have already tried that the other day but made no difference
Old 05-02-2007, 04:59 AM
  #44
Alvyn
Alvyn's Avatar
are you sure the rads not blocked?or is the thermostat the right way round as if not that could stop the water from being able to circulate around the engine?
Old 05-02-2007, 04:21 PM
  #45
ram
Has a large member
ram's Avatar
Alvyn didnt get a chance but will be checking all pipes etc for blocks 2moro
i changed the thermostat last week as a precaution and its in the right way round.
cheers.
Old 05-02-2007, 04:51 PM
  #46
SafeChav
SafeChav's Avatar
The rad being blocked is a good suggestion although it would almost definately overheat
Old 06-02-2007, 10:14 PM
  #47
GRIFFEN
GRIFFEN's Avatar
Pressure test coolant system,and see if pressure drops over 10-15 minute period,Manually check thermostat(pan of boiling water) to confirm it opens..,or try running engine without thermostat to see if problem persists..,check top and bottom radiator hoses,if one is definitely hotter than the other after initial warm up period so engine is at normal running temperature then you have a flow problem.
Old 07-02-2007, 05:26 AM
  #48
Benni
Ban[B][/B]ned
Benni's Avatar
Hope it's not too serious mate, Good luck.
Old 07-02-2007, 08:13 AM
  #49
LeviA
LeviA's Avatar
Sounds like it's got air trapped somewhere, I'd run the car up with the cap off the header tank and rev it periodically to see if it bubbles over.
If it does it's more than likely air trapped. You have to leave it to tick over I've found for 20 mins at least. Most people don't bleed the air out correctly.
It's worth a shot!
Old 07-02-2007, 01:15 PM
  #50
SafeChav
SafeChav's Avatar
Again if it was a thermostat sticking the car would overheat.
I'm still all in favour of a blocked pipe/air lock
Old 07-02-2007, 02:14 PM
  #51
ram
Has a large member
ram's Avatar
ive tried every 'get trapped air out' technique there is. although if people still have new ways of doing it i havnt tried then im still all ears
im still in favour of a blocked pipe too
but i wont know untill i get my lazy ass outside in the cold and start taking hoses off
Old 07-02-2007, 02:23 PM
  #52
antony215
Escort Rs Turbo
antony215's Avatar
Chop,chop then ive been out side in the cold as i had to put a new starter on and had to lay on the fucking cold floor
Old 07-02-2007, 03:27 PM
  #53
SafeChav
SafeChav's Avatar
Oh my fucking god you poor boy
bet that took all of 5 minutes lol
Old 07-02-2007, 03:37 PM
  #54
ram
Has a large member
ram's Avatar
well i went out and ran it one last time before i drain the anti freeze out and start taking hoses off.
ticked over for 40minutes and didnt over heat at all.
although i already established this last week,im just finding exuses not to start taking hoses off i think
better get cracking before it gets dark..
quick question though, what would actually block a pipe, its only water that runs through them?
also if this doesnt work, is the next step dash out to start checking out heater matrix etc
Old 07-02-2007, 04:20 PM
  #55
SafeChav
SafeChav's Avatar
Corrosion can block the smaller pipes up, on the metal connections normally, and thats where i would be looking.
You don't have to take the dash out you could just disconnect it and bypass it for now, but i doubt it that is going to make the level rise anyway
Old 07-02-2007, 04:54 PM
  #56
ram
Has a large member
ram's Avatar
cheers
this is a long thread for the tech room isnt it.. i hope it has a happy ending lol
Old 07-02-2007, 07:57 PM
  #57
antony215
Escort Rs Turbo
antony215's Avatar
Yeah but it was still in the cold
Old 07-02-2007, 08:50 PM
  #58
SafeChav
SafeChav's Avatar
Shut up you moany old tart
Old 08-03-2007, 06:14 PM
  #59
ram
Has a large member
ram's Avatar
right...time to resurect this thread
i havnt been anywhere near my car since early feb
but ive had a thought...
could the water be rising due to a lazy/knackered water pump?
i think this because the water level is fine when the car is idling but as soon as you rev the engine (and the water pump has to work harder to pump water around) it rises rapidly.
any opinions appreciated.
Old 08-03-2007, 08:18 PM
  #60
SafeChav
SafeChav's Avatar
If that was the case and it was the water pump that to me would say the water pump is working too effeciently, if anything.
Unrealistic in my eyes, sorry
Old 08-03-2007, 10:02 PM
  #61
Benni
Ban[B][/B]ned
Benni's Avatar
Your clutching at straws now mate. Hope you get it sorted.
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
mpilk
27-09-2015 09:21 AM
Quick Reply: Water rising in header tank
