What will happen if i take and blank my dump valve of
dump valve gots rid of the turbo presher when u let of the gass soo wot it does is it lets the turbo spin stiil so if u take it of it will stall the turbo when u let of the gas eg changre gear so the when u put on the gas agen u have got to get the turbo spinging agen by this time the chav in is 1.4 sr is just about to zipp past u hope this helps
ok maybe you could help me with something else im replacing my turbo this weekend and gunner spend a bit of money i was thinking upgraded turbo, intercooler any ideas what else i think my engine is totally standard apart frm the dump valve cheers i got about 600 squid
Escort Rs Turbo
A chip and k&n panel filter in the original airbox (if you've got it) and then a good setup on the rollers but you wont get all that done with £600 the turbo and intercooler will kill the £600
YE THATS WHAT I WAS THINKING MAINLY NEED HELP ON THE TURBO I DONT WANT TO GET SOMET THAT WILL MELT THE BLOCK BUT WANTING SOMETHING I CAN BUILD ON IF YOU NO WHAT I MEAN SEEN A NICE INTERCOOLER IN FASTFORD YOU MAY HAVE SEEN IT WITH THE 2 FANS 265 QUID
Escort Rs Turbo
t will send a feedback surge through the flux capaciter and you will no longer be able to get to 88 mph
i took my dump valve off, and it seems to idle better and run a lot smoother
i find that the more boost u run and a cone filter makes it louder mine does chatter a bit, nothing like a cossie tho
Escort Rs Turbo
They look ok for the money but id get a GRS one as people have seen good results with them they are a bit more money. Is there anything wrong with your turbo?? if not then you maybe better off getting a chip, intercooler, k&n panel filter in the original airbox and a - 31 actuator and having it setup as a standard turbo will be fine for 200 bhp (if in good health)
NA M8 ITS TOTALLY SHAGED HOUSINGS CRACKED MIXING WATER WITH THE OIL AND PISSING INTO THE PIPES THATS WHY I THOUGHT MIGHT UPGRADE, I HAVE KN AIR FILTER WAS TOLD ITS CHIPPED BUT HAVE NO PROOF
Escort Rs Turbo
Originally Posted by khanny
DERRRR JUST CLICKED ON BOUT YOUR 88 MPH LOL
rst230bhp DID YOU JUST TAKE IT OF AND LEAVE A HOLE
No he wont have you need to block it up and the small hose aswell
i blocked it off with a dump valve blanking plug on of these
http://cgi.ebay.co.uk/DUMP-VALVE-BLA...QQcmdZViewItem
200 bhp with chip, intercooler, cone and exhaust...hmmmn thats slightly optimistic. You could get a second hand turbo,exhaust and intercooler off here from people and traders and then a setup. You'd be looking at slightly over that budget though providing everything on your car is in good order, plugs, leads, dizzy etc, general servicing crap. A good service is very important as well as setup though!!!!!!
Escort Rs Turbo
