PLEASE CAN ANYONE HELP ZETEC TURBO WIRING LOOM
HI PLEASE CAN ANYONE HELP I AM BUILLDING 1.8 ZETEC TURBO TO GO IN MT 1.6 SI FIESTA IM STRUGGLING TO FIND AN RS TURBO LOOM AND OFAB ECU FOR SENSIBLE MONEY AS IVE SPENT LOADS ON ENGINE AND IM ON A BUDGET IM LOOKING FOR A CHEAP LOOM SOLUTION IF POSSIBLE IDE LIKE TO KNOW THE DIFFERENCE BETWEEN XR2I ENGINE LOOM AND A FIEASTA RS TURBO LOOM AND WHETHER I CAN ADAPT ONE TO FIT AS THEY SEEM MASSIVELY CHEAPER ALSO CAN I PLUG OFAB ECU (RS TURBO) INTO XR2I LOOM PLEASE MAIL ME IF YOU KNOW OF ANY SOLUTIONS TO MY PROBLEM ITS VERY DEPRESING AS IM PICKING BLOCK HEAD AND ALL NEW ENGINE COMPONENTS UP TOMORROW FROM ENGINEERING SHOP AND ONCE ITS BACK TOGETHER I CANT RUN IT !!!!!!!!!
A 2i loom will see you through its near on the same thing.
You can plug OFAC straight in with its matching MAP sensor, cut 1 wire and your away.
For OFAB theres also a couple of pin changes and you will need to change the plug to accept the Marelli MAP sensor
Cameron
14
09-08-2015 06:28 AM
