Escort cosworth dash clocks
Old Sep 3, 2004 | 10:20 PM
mk5_cossie_cab's Avatar
mk5_cossie_cab
Default Escort cosworth dash clocks
Can anybody help i hve the dash clocks from an escort cossie in my cab relica but the fuel and temp side of the clocks do not light up when you turn lights on can this be rectified.
Also the are two wires coming out of the back of the clocks which i hve been told go to the centre clocks to light them up but i dont no which wire goes to which pin the wires are marked as 1 and 2.
Old Sep 5, 2004 | 05:11 PM
Dave Henshall's Avatar
Dave Henshall
the escos uses electroluminesence to light the clocks, not bulbs. it uses an inverter to transofrm the 12vdc supply do a AC at higher voltgae , this makle sthe actuall faces of the clocks glow - soulds like you need the whole escos instrument cluster not just bits of it.
Old Sep 15, 2004 | 12:30 PM
Damo V's Avatar
Damo V
re the out puts iirc, one is longer than the other, abnd the same on the wires they plug into....
Old Sep 30, 2004 | 11:01 PM
mk5_cossie_cab
I know this but i have no loom to centre clocks need to know which wire goes to which pin
Old Oct 4, 2004 | 03:42 PM
Damo V's Avatar
Damo V
TBH, I wouldnt think it makes that much difference anyway mate, otherwise there would be a plug or "handed" wires
Just plug em on and see what happens
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
