Any1 know how to change the oil seals on a t3 garret turbo
i dont know if you can remeber my light issue with the brown leads to the battery but the side lights come on but when flicked to main beam they go off plus no dashboard lights any ideas m8 and the brown leads did go to the live wasnt it i cant remeber what was said and cant find that post now havwent touched the car for a few days so forgot
sorry m8 u say brown are always earth but the car wont start when i connect to negative but does at live just wanted to check thats all i know not avin much luck wiv this am i
The smaller relays are the lighting ones, and the bigger square ones are ignition ones etc.
Try replacing them all, but to be honest a relay shouldnt fry from reversed polarity.
Don't know any sites as such.
I did my own turbo but i didn't take any pictures of it, i planned to but just couldn't be arsed in the end as time was against me
Wouldn't want to try and explain without pictures
How much did you sell the other turbo for just out of interest?
50 quid m8 with manifold and elbow just what i payed 4 it it was shagged tho m8 if id have put it on it would have caused some right damage there was that much play in it EBAY NUMBER 200063962998 did you find it very hard to do the turbo m8 and when rebuilding with the kit does that iliminate play in the shaft
Ah ok fair was just curious.
I didn't find it THAt hard, its not the easiest job but i'll give anything a bash im usual successful. Theres some clips inside that are a right fucking cunt to do though, and thats with circlip pliers and i somehow managed to do it without
As i said, the kit won't necessarily eliminate play, depends whats worn........general ruls though if theres play its more than seals that are worn..........
the 1 thats on dosnt have that much play in it to be honest so hopefully i will get away with it
i really do cos im even conteplating getting rid and i really dont want to but im havin to drive round in my wheelie bin cleaning van and thats not good
had it a month now and still only drove it for 2 days im really pissed of
Couldn't tell you mate. Its standard! And ive only spent 6 weeks driving it which worked out to be 3,500 miles
Took longer doing all the work to it. Standard boost, K&N, Scorpion system, ported and polished head and it did have a power engineering cam but that went (and was part of the reason i took it back off the road)
Did the rev limiter in 5th though
tell u 1 thing my cars got and i aint got a clue what it is theres a silver button been put on the leftnear the steering wheel when pressed you can here a click neaar the intercooler any ideas what it could be i thoughgt it might have bween 4 the fan but its not
That will be 2 stage boost control i expect. Theres a brown and beige round thingy on the gearbox that will be making the clicking.
Nah never made a MK3 turbo, i did it myself! Wish i knew then what i do now..............would never of put the MFI into it
big_Rad
15-09-2017 09:36 AM
ekjim
17-08-2015 08:57 PM
st220kyle
16
14-08-2015 06:13 AM
