Series 1 Starting/running problem
Old Dec 29, 2006 | 02:50 PM
boXXer's Avatar
boXXer
GASH!
Default Series 1 Starting/running problem
hello! on my series 1, when i try starting it from cold, it doesnt want to tick over, even when you try to accelerate, the engine just cuts out. It ticks over very lumpy (about 400rpm) for about 5 mins, then sorts itself out, BUT, when you drive away, under load after about 10 minutes of usage, the engine cuts completely and doesnt want to restart very easily. but then afterwards, it is perfectly ok.
Could it be a sensor problem? if so, where do i start?
Any help would be great.
Cheers!
Old Dec 29, 2006 | 03:53 PM
Alvyn's Avatar
Alvyn
sounds as though could be a metering head issue!
Old Dec 29, 2006 | 10:53 PM
boXXer's Avatar
boXXer
GASH!
think your right mate. Had a play today as it wouldnt start, and now it runs good. Will try in the morning when its cold.
Becka674
11
Oct 8, 2015 03:11 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Bransby
Sep 11, 2015 01:09 AM
