Oil pump question ....
Old Dec 25, 2006 | 09:36 PM
2wd's Avatar
2wd
Default Oil pump question ....
Hi .... so what should approx oil pressure be on a uprated 4wd oilpump ??
Thing is that I ordered a uprated pump where I got my engine rebuild, but I think it a bit low ..?
idle .............. 55 psi cold and 28 psi hot
2000 rpm ..... 40 psi hot
3000 rpm ..... 48 psi hot
raising to approx 52-55 psi hot when taking higher rpm's.
I dont know if it matters, but I have a external oilcooler mounted and i'm using a mobil 1 oil, (5w50) ??????
Old Dec 26, 2006 | 07:18 AM
JanDK's Avatar
JanDK
hmm.. same as mine! Hope it is ok. I think my pump is standard!
Old Dec 26, 2006 | 11:59 AM
2wd's Avatar
2wd
JAN : well...if its std it should be around these figures....but as you know ...Entech did my engine and they where told to mount a HP oil pump...and looking at these figures ...well ... I think that something is not as it shold be....
so please anyone...have a look at this, and let me know what you think....
Old Dec 26, 2006 | 03:57 PM
rapidcossie's Avatar
rapidcossie
i have nearly 80 psi when stone cold and over 60 when hot and over 4k revs.
Old Dec 26, 2006 | 04:46 PM
2wd's Avatar
2wd
and that is on a uprated pump...??
if so it Looks like something is not ok in my case...
Old Dec 26, 2006 | 06:52 PM
Alvyn's Avatar
Alvyn
what grade of oil are you using? as this can have an affect also!
mine with 10/60 Millers from cold 75psi dropping to 60psi when warm(at full throttle) 45psi on tick over!
Old Dec 26, 2006 | 07:37 PM
2wd's Avatar
2wd
Old Dec 26, 2006 | 07:47 PM
2wd's Avatar
2wd
thats about 20 psi higher than mine from cold and 20 psi over at idle when hot ...
Old Dec 26, 2006 | 08:20 PM
rapidcossie
the external cooler wil make the oil pump work harder but should effect overall pressure i dont think..
mine is a 4x4 modified pump from mountune
Old Dec 26, 2006 | 08:59 PM
trevCOSS's Avatar
trevCOSS
Default Re: Oil pump question ....
mine is up about 5psi on these figures, new standard pump on new bearings regrond crank etc
Old Dec 26, 2006 | 09:00 PM
2wd's Avatar
2wd
ok...mine is also a 4wd pump, and should be with a uprated spring .... buuut it looks like that either they "forgot" it or there is another problem.....
Old Dec 26, 2006 | 09:07 PM
2wd's Avatar
2wd
hmmm..sound like I only got at std pump ...but payed for a uprated
I also got new bearings and so on as it was a complete rebuild... ....
so if there was another problem...what could that be ??
Old Dec 26, 2006 | 10:17 PM
costina's Avatar
costina
Live long and prosper!!
Tom those figures are for a std pump mate BUT as alvyn said oil grade makes a difference
an uprated pump should be around 80 psi cold
But it is not such a good idea to have too much pressure,because all the oil gose to the top quickly and only has a hole the size of 22 mm approx to return to the sump= bottom end failure if low on oil
These are mine 60 psi cold
32 psi hot at idle
this is on mobil 1 motorsport 15/50
I personally think your oil is too thin
BUT your figures are in spec
Old Dec 27, 2006 | 03:12 AM
2wd's Avatar
2wd
32 psi hot at idle
thanks...about the oil.. I used the old mob 1 , 5-40 the first 6 years I had the cossie...then I went to gastrol RS 10/60....but after a couplen of years I was told that it was to thick, so I found this mob 1 oil 5/50 and "Oilman" from PF told me it was ok as long as I changed it regulary..and I do...at about 4-5000 km, but yes pressure dropped a bit when I changed it....
About the pump...its just that I cant understand why it has std pressure when the pump is a uprated(I got it myself from Woodford)....could anything be wrong... the engine is a 4wd rebuild only change is that its in my 2wd sapp, and therefor it has a 2wd sump...???
Old Dec 27, 2006 | 09:41 AM
costina's Avatar
costina
Pick up pipe too close to bottom of sump restricting flow and what dip stick are you using??????
Old Dec 27, 2006 | 01:45 PM
2wd's Avatar
2wd
hmm... could be...how do I find out ?? And if so how can I solve the problem ?
Its a complete 4wd engine, except for the sump ... so dip stick is 4wd.
why ??
Old Dec 27, 2006 | 05:09 PM
costina's Avatar
costina
Right dip stick will read wrong as its a different size and different markings on it to a 2wd item, i believe that the 4wd oil pump and pick up sits lower than the 2wd item u will need to comfirm this with a tuner ask stu @msd or mark @madevelopments or someone on here will no for deffo....
needs to be sorted
Old Dec 27, 2006 | 07:58 PM
2wd's Avatar
2wd
Right dip stick will read wrong as its a different size and different markings on it to a 2wd item, i believe that the 4wd oil pump and pick up sits lower than the 2wd item u will need to comfirm this with a tuner ask Stu @MSD or mark @madevelopments or someone on here will no for deffo....
needs to be sorted
Ok..I'll ask right away !!!!
Old Dec 27, 2006 | 08:04 PM
rapidcossie
did a peak recal on my oil pressure and i have seen 80 psi at one point...
maybe when its revved to 8k
Old Dec 27, 2006 | 08:29 PM
costina's Avatar
costina
so thats 80 psi most of the time then Euan
Fair play give it some
Old Dec 27, 2006 | 08:43 PM
rapidcossie
very rarley gets revved right out in each gear...
dont really need too.
that peak recall was from daddy thrash i think which would have seen 8k in 4th then well over 7k in 5th
Old Jan 5, 2007 | 11:49 AM
2wd's Avatar
2wd
hi..just checked the gab .... on my old 2wd engine the p/up to sump looks like about 10 mm and when looking at my 4wd engine with 2wd sump, it looks like the gab is about 5-6 mm ..... so would that be ok ??
if so the pump must be a std 4wd pump... or there is another problem.. ...... ???
Old Jan 7, 2007 | 03:54 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
The grade of oil is vey important, i had oil from a mate who works at BMW and my oil pressure went to 40psi when cold and dropped to as low as 12.5psi when really hot, i shit my pants and changed to mobil 1 15/50 and it read 60 when cold and 33 when hot, i only have a standard pump too
hope this helps a little
Old Jan 7, 2007 | 04:53 PM
2wd's Avatar
2wd
ok...I have found a Q8 fully syntectic 10w50 oil and I will try it when I get my car back on the road in mar/april ...then we'll see..
Old Jan 7, 2007 | 07:01 PM
rabmc's Avatar
rabmc
Had 80 when i start engine and when hot after a run its sits around 35sih
Dont have a clue what pumps in there though
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
hopper350
Sep 4, 2015 12:53 AM
