air fuel meter
Old Dec 31, 2003 | 04:12 PM
STUCOS's Avatar
STUCOS
Default air fuel meter
just ordered an auto meters air fuel meter to monitor the mixture of my 3dr,but how do you wire the dam things up.i am running 4x4 t34 so there is a fitting for a lamba sensor but what after that,do i use a standard 4x4 lamba?
cheeRS stu
Old Jan 1, 2004 | 07:23 AM
http://homepage.ntlworld.com/giovann...ompics/afr.jpg
This diagram should explain you will need a 3 or 4 wire lambda to get best results these have heaters and can be bought from http://www.lambdasensor.com/main/mtypes.htm
Old Jan 1, 2004 | 10:38 AM
STUCOS's Avatar
STUCOS
thanks jimbo,hope it helps me,do you want to pop over when im ready and wire it up
cheeRS stu
Old Jan 1, 2004 | 10:52 AM
flashpoint's Avatar
flashpoint
Go for a 4-wire sensor or you can end up with inaccurate readings due to the volts drop developed across the engine earth strap, as the alternator charges the battery or when you have the head lights on!!
You can go one step further and fit an isolated 12 volts supply to the meter/sensor.
This isolates the ground loop affect and will make the meter as accurate as it can be!!
Cheers.
Steve.
Old Jan 1, 2004 | 11:52 AM
STUCOS's Avatar
STUCOS
steve can i get that in english please,me and electrics dont go that well
cheeRS stu
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
