and another problem [over heating]
Old Dec 16, 2006 | 09:19 PM
khanny's Avatar
khanny
Default and another problem [over heating]
as most of you might have read my prevouse threads ive had that many on here over the past 2 weeks i took all the turbo pipes and the coolant pipe that goes fron the radiator at intercooler side then goes into hte block, after a run today noticed steam coming from the bonnet it didnt read on the temp gauge i was c0ooking but the anount of steam that came from the header tank when opening slowly was unberlivable im suprized it didnt explode, now im thiking its a air pocket but it seems like water is geting into the rocker cover as when i take the yellow cap of the top its white sludge so i was thinking head gasket buti changed the oil and no sighn of water in the bottom at all, maybe the water and oil are mixing in the turbo that might be the problem im having with the turbo[ the water thats used to cool the turbo] any ideas any 1.
1 more thing i was givin diffrent advice on hear other day as to wether the brown battery leads go to live or neutreal like a div i wired them to live with out checkin proply first any way now the main beam wont come on side lights do was a bit dodgey driving back in the dark tonight i can tell u also the indicators dont work but hazards do, ive checked all the little fuses but none are blown any ideas on this 1 any1
sorry bout such a long post and i hpoe some1 can be arsed t read it i just need to sort this car out still only drove it 4 about 3 hours all together
Old Dec 19, 2006 | 11:23 PM
NEWTON's Avatar
NEWTON
the water system might be pressuring up or may be you have a air lock
Old Dec 20, 2006 | 12:01 PM
Dave_Hay's Avatar
Dave_Hay
are you sure its circulating properly?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Rammer46
Sep 18, 2015 08:31 AM
cossie09
Sep 10, 2015 06:56 PM
BRAM
Sep 8, 2015 07:11 AM
