Ka Zetec 2.0
Old Dec 5, 2006 | 06:23 PM
Hobomassiv's Avatar
Hobomassiv
Default Ka Zetec 2.0
I have just bought a 2.0L Zetec silver top from a Mondeo.
I am going to be fitting this into my Ka. As far as I know I will need to swap the following:
Flywheel – Swap for an escort 1.8 one.
Sump – Also escort 1.8
Starter motor will be a Ka item, and will mate up with the flywheel.
As far as I know to actually fit this engine ill need to.
Rebuild the engine (cleanup etc no new parts unless necessary)
Sort the mounts out
Drop in the engine and connect to gbox
Wire up the loom + ecu and then connect it to the car loom
Fill up with fluids
Then im ready to go?
Ill be doing all the engine work separate from the car and then I plan to have a week in feb or so where I can just put the engine and everything else in.
Ill be doing the puma brake conversion sometime soon.
Is there anything else I need to do / buy and is there anything major ive forgotten?
Old Dec 5, 2006 | 06:35 PM
Wardy257's Avatar
Wardy257
Unless you intend to keep the mondeo power steering pump you will also need a 1.8 waterpump.
Old Dec 5, 2006 | 07:15 PM
Hobomassiv's Avatar
Hobomassiv
I was thinking of getting a non PAS Ka rack and putting that in. Im not too sure yet.
Old Dec 5, 2006 | 09:14 PM
slimwynn's Avatar
slimwynn
i doubt u will have room for a power steering pump but u will need a 1.8 water pump as u will have to bring the alternator from the back to the front witch in turn changes the way the belt fits
Old Dec 6, 2006 | 01:11 PM
Hobomassiv's Avatar
Hobomassiv
Right im going to pick up the engine on saturday, its got pretty much everyhting except the gearbox.
Ill pop down the scrappy as well in the morning and try get a few bits.
Ill probly try to find:
1.8 Water pump
1.8 Flywheel
1.8 Sump
Most of the other bits i will get elsewhere.
One thing i was thinking was, will the CV joints be able to cope with the power, or is it a matter of not flooring it everywhere?
Rob
Old Dec 6, 2006 | 06:07 PM
Wardy257's Avatar
Wardy257
I'm pretty sure you will need an Escort ZETEC sump and oil pick up pipe, dont go buying a Mondeo 1.8 ZETEC sump etc.
Old Dec 6, 2006 | 06:44 PM
slimwynn's Avatar
slimwynn
I agree
The gear box does'nt fit with the mondeo sump.
Old Dec 7, 2006 | 12:15 PM
joey-p's Avatar
joey-p
i have done this conversion. and i have PAS.
im fitting a focus rs engine in now. im selling every thing todo a 2.0 into ka conversion for 1800. i have someone comeing to have a look tomz eve, but email me if your intrested.
joe
Old Dec 7, 2006 | 01:36 PM
Hobomassiv's Avatar
Hobomassiv
I was gonna ditch the PAS because currently mine is buggered, and it would be easier jsut to remove it
Did you use the mondy pump or the Ka one?
Old Dec 7, 2006 | 07:00 PM
joey-p's Avatar
joey-p
mondao one and still used the escort waterpump.
custom mount for the alternator and a idle pully.
im runig at about 160bhp and its realy good fun. i think a LSD out of a BC box will fit the ka ib5. if you can find out if it dose it might be woth fitting one as there pretty cheep second hand. it wheel spins alot.
Old Dec 7, 2006 | 07:03 PM
joey-p's Avatar
joey-p
havent got any recnet pics, but this is the most up to date i have when i was almost done .
Old Dec 10, 2006 | 08:57 PM
Hobomassiv's Avatar
Hobomassiv
I got a question joey.
Where did you get your engine mounts from?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
