ABS Wiring need help :(
Old Dec 5, 2006 | 06:09 PM
Alan s1's Avatar
Alan s1
Default ABS Wiring need help :(
Hi i swopped my wiring loom over on the cossie to a Standard Loom (main car loom) And have thined it out alot This is all working in the car
But i have the 2 Plug set up for the ABS where as my ABS In the Cossie has just 1 plug Now i have the plugs off the other looms (IE the single plug and the other 2 plugs) as i was hoping to just rewire it into 1 plug BUT the wires are'nt the same
SINGLE PLUG WIRING COLOURS ARE ;
BLACK/GREEN , YELLOW , EMPTY , BLACK
BROWN/YELLOW , YELLOW , BLACK/BLUE , EMPTY
THE 2 PLUG SETUP
RED , BROWN/YELLOW
BLACK/BLUE , YELLOW
OTHER END OF THE PLUG IS THE SAME AS ABOVE,
THE OTHER PLUG
RED/BLACK , YELLOW
BLACK , BLACK/GREEN
OTHER END OF THE PLUG ONLY HAS 3WIRE SEE BELOW ,
RED/BLACK , YELLOW
BLACK , EMPTY
SO CAN SOMEONE HELP ME ASAP PLEASE
Just joined the wires up from the older ABS plugs to the newer ABS plug and i have found this
I seem to have a RED wire on one plug and a RED/BLACK wire on the other Plug (this is on the older ABS setup plugs) Theres no wires with these colours on the NEWER ABS setup Can i just leave them out
Old Dec 14, 2006 | 06:11 PM
Alan s1's Avatar
Alan s1
Anyone Please
Old Dec 14, 2006 | 06:49 PM
velocity's Avatar
velocity
to be honest your post is very confusing with so many plugs i,m a tad lost
but if its any use i can email you a cossy 2wd and 4wd wire diagrams for the abs system and you may be able to hook up some connections, it helped a lad out earlier in the year with a similar problem and situation
pm me an email address if you want them
Old Dec 15, 2006 | 03:35 AM
Alan s1's Avatar
Alan s1
You have PM
Old Dec 15, 2006 | 04:14 PM
velocity's Avatar
velocity
email sent
Old Dec 15, 2006 | 05:53 PM
Alan s1's Avatar
Alan s1
Thanks
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
