Testing ESCOS Amal Valve
Old Dec 5, 2006 | 12:31 PM
bpspa's Avatar
bpspa
Default Testing ESCOS Amal Valve
How do you test an amal valve, and what are the symptons of it failing.
Thanks
Ben
Old Dec 5, 2006 | 01:24 PM
SafeChav's Avatar
SafeChav
Just connect it up and see if it clicks, if it does then it is almost definately fine!
Old Dec 5, 2006 | 05:40 PM
bpspa's Avatar
bpspa
cheers mate, but I haven't got a new unit, but wanted to test whether it was working correctly
would unplugging the connection and then plugging it back in be sufficient?
Old Dec 6, 2006 | 09:00 AM
SafeChav's Avatar
SafeChav
Just disconnect the plug and connect 12v across it, when you connect it up it will click on, and then click back off when you disconnect it.
Its not 100%, but generally when they break they don't make the clicking noise which indicates they are operating internally.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
