Lowering springs
Old Nov 16, 2006 | 06:26 PM
iancseries2's Avatar
iancseries2
Default Lowering springs
on my series 2 ive got standard springs ive just brought meself some brand new lowering springs, ive got a spring clamp to change the fronts but are the rears as simple as jacking the car up and letting the trailing arms drop down and put the new springs in? Am i just beong a bit thick it just seems to easy!!!!!!!!!
Old Nov 16, 2006 | 06:37 PM
sexr3i's Avatar
sexr3i
isn't it
it is that easy you'll have to disconnect the rear arb if fitted too though. support the bottom arms with a jack then let it down slowly once you've undone the bolt at the end under the middle of the car, stops the spring pushing down with the force of it compressed and possibly causing injury
Old Nov 16, 2006 | 09:34 PM
SafeChav's Avatar
SafeChav
Bollucks to that! Undo the 2 bolts hodling the shock to the hub, MUCH easier, and you don't have to worry about anything flying out, and its also a LOT easier to get the hub back inline with the shock, those inner arm bolts are hard enough when you are bolting up the arm with nothing else connected, let alone figthing against the shock, tie bar, rollbar and the spring!!!????
Old Nov 17, 2006 | 06:23 AM
iancseries2
wicked cheers for your help looks lke im gonna b busy sat!!!!!!!!
Old Nov 25, 2006 | 04:29 PM
sexr3i's Avatar
sexr3i
isn't it
huh? just done the rear springs on our stripped mk3 and havent had any of the probs you just mentioned, nothings fighting you as the spring is compressed by the extra jack under the arm....
undid the back bolt, lowered the jack, levered the arm down, spring out, new one in, jacked up the arm, bolt back in. 20 mins a side?!
Old Nov 25, 2006 | 04:34 PM
SafeChav's Avatar
SafeChav
Dunno about that, if your tellin me that inner bolt was a piece of piss to line up even with a jack then maybe i shouldn't be touching cars cos i can't say im convinced
Old Nov 25, 2006 | 04:44 PM
sexr3i's Avatar
sexr3i
isn't it
lol, seriously. use the jack to get it about right height, push or pull it to get it in line horizontally then bash the bolt thru with the lump hammer, if it's out a smidge it'll pull it into line...
Old Nov 25, 2006 | 04:54 PM
SafeChav's Avatar
SafeChav
hmmmmm.......as it thought....
its this bit im not overly fond of....
But im a picky cunt like that, i find generally smashing bolts through chips paint etc
Old Nov 25, 2006 | 05:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
Ive done a few buy just jacking up the car and using two crowbars
Old Nov 25, 2006 | 05:14 PM
SafeChav's Avatar
SafeChav
So there really IS some crazy people out there
Old Nov 25, 2006 | 09:46 PM
Aaroncast's Avatar
Aaroncast
note!! depending on how short the springs are!! on occasions weve had to use a tie wrap top and bottem so they dont dislodge on full droop!! in fact a sports car firm in nottingham!! used a piece of rope as part of there lowering kit!!!-thats no joking either (this only relaites to rears by the way-last thing you want going over a fast yump!!!!!!!!!!!! --guru7001/2
Old Nov 26, 2006 | 09:55 PM
SafeChav's Avatar
SafeChav
If your fitting springs that low you should really be finding some shocks with shorter shafts aswell.
Old Nov 26, 2006 | 10:32 PM
sexr3i's Avatar
sexr3i
isn't it
lol, dont take it over the top, i meant, if its not 100% lined up, say 80%, then seeing as the head of the bolt isnt square, give it a love tap and it will pull into line... thats why they make the bolt heads like that, so they "start" to go into the hole when it's not fully lined up?
Old Nov 28, 2006 | 01:14 AM
SafeChav's Avatar
SafeChav
Hmmmmmmmm
I'll stick with my method i think
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
richierich1986
Sep 18, 2015 03:29 PM
Adam Graham
Sep 6, 2015 06:04 AM
