Sapph cos 4x4, three problems...
Old Aug 26, 2004 | 07:44 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Sapph cos 4x4, three problems...
Ok, stage 1, just put the head back on after a full rebuilt - I have three problems at the moment:
-First, there's smoke coming out from the exhaust manifold area, it smells oily. Only thing I can think of is that I couldn't get the plug to return oil to the sump from my breather to screw in completely. I haven't cross threaded it cos it was real easy to screw in at first. Looking down with a torch, it doesn't appear to come from there. Can the new exhaust manifold be the cause. One of those things that gets better with time ?
-Second, she starts ok, rev her up and let go of throttle, she goes back to idle, starts hunting and stalls. That only seems to happen when she has warmed up.
-Third, I found this on the floor, I think it comes from the standard breather system which is now in the bin, can you confirm please ?
Due in for an MOT on sat morning, so I would like to sort it all out before then.
Thanks, your help much appreciated
Old Aug 26, 2004 | 07:51 PM
wimwerf's Avatar
wimwerf
the first one----> dont know
the second ----> maybe your throttle position sensor is failing
the third ----> yes it comes from the breather under the inlet.
correct if im wrong
Old Aug 26, 2004 | 07:55 PM
frog's Avatar
frog
Thanks winwerf, so for the third one, I can chuck it in the bin with the rest then.
Old Aug 26, 2004 | 09:06 PM
frog's Avatar
frog
Any suggestions folks ?
Old Aug 27, 2004 | 07:17 AM
frog's Avatar
frog
BTT
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
