Cossie small turbo "chugging"...
Old Oct 21, 2006 | 06:16 PM
ThomasV's Avatar
ThomasV
Default Cossie small turbo "chugging"...
Hi all,
I have a Esc Cossie T28 and it has a annoying problem.
If I floor it, then the car chugs and pulls very uneven .... if I only give it 4/5 throttle....then it pulls perfectly and everything is fine!
The problem ONLY occurs at full throttle ?? ..... what could be wrong?
I have changed the spark plugs ... didn't help.
The car is 100% standard.
Thomas
Old Oct 26, 2006 | 08:39 PM
ajjames's Avatar
ajjames
maybe it is over boosting and hittting overboost
Old Oct 27, 2006 | 08:17 AM
ThomasV's Avatar
ThomasV
You might be right ...
I think it is a faulty map-sensor ....
Will change it to see....
Cheers for the input!
/Thomas
Old Oct 27, 2006 | 08:52 AM
sailorbob's Avatar
sailorbob
Have you tried putting a error code reader on it? Trial and error sensor swapping soon gets expensive.
Old Oct 27, 2006 | 11:20 AM
ThomasV's Avatar
ThomasV
Unfortunately, I don't have access to a error-code-reader.
I could go to FORD but this would also be rather expensive and often they really don't knwo too much about these cars. (not in Denmark anyway)
But I will give them a ring, just to be sure.
Thomas
Old Oct 27, 2006 | 12:25 PM
JanDK's Avatar
JanDK
korrekt Thomas syns at have set error-code dimser på ebay
Old Oct 27, 2006 | 12:43 PM
sailorbob's Avatar
sailorbob
Most independant garages should have a code reader suitable for Ford cars (3 digit enhanced) and will probably be cheaper.
3i Jim
Nov 20, 2015 05:12 AM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Bailes1992
Aug 16, 2015 07:14 PM
