Gearbox experts help needed please
Old Aug 24, 2004 | 07:35 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Default Gearbox experts help needed please
What is the cause of this or is it down to my sedate driving style ?
btw Its from my MKII RS2000 4 Speed box (3rd and 4th synchro)
Gearkit is a Tran-X s/c c/r
Old Aug 24, 2004 | 08:26 PM
markk's Avatar
markk
its just a general wear thing m8 , the brass synchro rings are original ford parts and do not last forever , these are the cut outs for the shfter blocks to sit in , behind them goes the springs that keep the tension on the shifter blocks which in turn hold the selector sleeve in the selected gear , just werar and tear !! fit new ones all will be well !!
Old Aug 24, 2004 | 08:44 PM
RS2000CUSTOM
cheeRS markk
Burtons do these synchros in steel so may go for them as this will be the 2nd set of brass I have fitted in the last 6 months
Any thoughts on steel items £
Old Aug 24, 2004 | 09:03 PM
markk's Avatar
markk
RS2000CUSTOM,
sounds like your a bit rough on the change m8 !!
the steel ones are very expensive iirc , and the problem with them is where as the brass item sbreak the steel units just bend , i.e the teeth burr up and make selection impossible , make sure you got a good clean magnet in the bottom to catch the fillings if you do , then of course cause they dont break , the gear will then bear the brunt of the rough change !!
the solution ------
dog box !!
Chas
Sep 21, 2015 08:57 PM
cos elle
Sep 1, 2015 06:48 PM
Ben26
Aug 11, 2015 04:19 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
