peugeot expert misting up
Old Sep 14, 2006 | 07:35 PM
turbo1973's Avatar
turbo1973
Default peugeot expert misting up
hi having problems with my van the windscreen been misting up when its raining and when you put the blowers on to clear it it seems to get worse but i noticed hardly any air comes ot the windscreen vents but the rest work fine any ideas its getting annoying when your stuck in traffic trying to get home but if you use the air con it clears in seconds
Old Sep 17, 2006 | 07:59 PM
MarkN's Avatar
MarkN
Don't know if this has a pollen filter but if it does it almost certainly needs replacing.
Mark
Old Sep 17, 2006 | 09:06 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it would clear in seconds with a/c - that's one of it's key functions
the reason it works as the a/c makes the evaporator cold, so any moisture in the air condenses on it so that the air coming off it is very dry.
the downside is, that the moisture stays on the evaporator after the a/c is switched off, so it gets blown up onto the screen and mists it up again. it's a viscious circle.
if you can, dry the evaporator sometime by running the fan at full speed, with the heater on full blast pointing at the floor vents and in recirculation mode with the windows open.
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
