Alarm Troubles not too bad though.
Old Aug 22, 2004 | 02:38 PM
MikeyXR2i's Avatar
MikeyXR2i
Default Alarm Troubles not too bad though.
Hi Peeps, i got a little problem with my alarm, i never put it in so there might be a few dicky wires!! Its a Laserline system, locks and arms it self if you leave the car open, but when you put the car in the garage and arm it, in the middle of the night the system will false alarm, so now i leave it switched off to stop it doing it, so just the immobilser is on.
Anyone have an idea what it could be?
Thanks peeps
Regards Mikey
Old Aug 24, 2004 | 04:13 PM
Dave Henshall's Avatar
Dave Henshall
it should (IIRC) flash the led a number of times or beep a different number of times than normal whenu disarm the alarm, this will indicate what triggered it,
2 favourites are ultrasonics , and the bonnet pin switch, as these are at the front, they geta ll the rain/spray and salt in them and fail veryt often. , is it a 966 or 993 (2:1 upgrade) model? i thinki have an old handbook in mt draws somwhere
Old Aug 24, 2004 | 04:21 PM
MikeyXR2i's Avatar
MikeyXR2i
cheers for that reply dave, i will find out the model later,
Old Aug 31, 2004 | 06:40 PM
MikeyXR2i's Avatar
MikeyXR2i
Hi dave, checked the system out, its the 996 Model.
Old Sep 1, 2004 | 10:09 AM
Dave Henshall
ill have a dig around for the book.
Old Sep 1, 2004 | 03:43 PM
MikeyXR2i's Avatar
MikeyXR2i
i got the book for it, just wasn't sure where to start on the fault finding side of things. I need to get a key to for the siren to disable battery backup as i aint got one.
Old Sep 1, 2004 | 08:10 PM
Dave Henshall
here goes...
when you disarm the alarm, but DONT turn the ignition on (ignition cancells the sens and tell) the LED will flash a number of times in a morse code type sequence as follows:
flash pause, flash pause etc = volt drop (interior light, mobile phone charger, radar detector etc)
flash flash pause, flash flash pause = interior detection(ultrasonics) ie open window, sunroof, open air vent and gust of wind.
flash flash flash pause, flash flash flash pause = earth contact, ie door swicth, boot or bonnet switch.
4 flashes and pasue repeated (u get the idea....) = shock sensor
5 flashes and pause repeated = ingition energisation - ie someone trying to hotwire it.
6 flashes and pause repaeted = disconnection of main car battery or supply to the alarm.
hope this helps,
cheers, dave.
Old Sep 1, 2004 | 08:45 PM
MikeyXR2i's Avatar
MikeyXR2i
Cheers Dave, will have a look at it now you put that up, cheers m8.
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Fordmad!
Sep 29, 2015 07:03 PM
A.t.p
Sep 29, 2015 05:04 PM
