throttle position setup
Old Aug 20, 2004 | 09:41 PM
velocity's Avatar
velocity
Default throttle position setup
i,m trying to set up the sensor but its not working out the throttle body is off the car and so,s the head and all the rest,heres my problem
suposedly when you put an ohm meter between pins 30 and 17 on the sensor to measure the moving contact resistance i should get an infinite reading at idle and resistance should rise as i open the throtle to full, but i,m getting 480 ohms or there abouts at idle and resistance decreases as i open the throttle but it doesent quite reach zero ohms at full open ,now can i assume that if i set the sensor to zero ohms at full throttle it will be ok,i have heard somewhere that some sensors work the opposite way. i have tried this already and found that the sensor is at full adjust in the sliding slots at zero ohms,
the other resistance reading between pins 11 and 30 is ok at 540 ohms
the car is a 1992 sapg 4x4 and the sensor is red in colour and i would be greatful for and help as when its all in the the car its a bitch to get at
thanks
Old Aug 21, 2004 | 10:22 PM
velocity's Avatar
velocity
anyone i am badly stuck for this
Old Aug 22, 2004 | 05:26 AM
dave green's Avatar
dave green
With the ignition on turn the switch untill it clicks, thats how i always do it.
Dave
Old Aug 22, 2004 | 08:52 PM
velocity's Avatar
velocity
thanks dave but i dont have the luxury of ignition at the moment or will gave for a few weeks . when you say the switch do you mean the sensor body?
thanks
Old Aug 23, 2004 | 09:07 AM
Dave Henshall's Avatar
Dave Henshall
right,
the voltage reading across pins 30 and 17 at the ecu with the ignition on should be between 0.2 and 0.25 volts DC. this is also you will notice where the TPS sits almost exactly half way along its elongated slots.
cheers, dave.
Old Aug 23, 2004 | 08:56 PM
velocity's Avatar
velocity
thanks all for the info have it sorted now
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
