2.0l zetec in mk3 xr2i
a friend of mine is going to carry out a zetec conversion into his cvh'd xr2i. just got a few questions:
would an rs1800 or xr2i 16v engine mount work?
would the existing management work?
You will need mounts from any Zetec powered Mk 3 Fiesta. You will need a non-PATS ECU from a mondeo or aftermarket ECU (far, far better).
Unless you keep the original PAS set up you will need to use the 1.8 waterpump, the 1.8 flywheel is also lighter if you can get one.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
