Ignition Problem
Old Aug 5, 2006 | 07:12 AM
thething84's Avatar
thething84
Default Ignition Problem
My 2.0 16v mk1 mondeo now has an ignition problem.
i have just fitted a new alarm and taken the old one out. I know its nothing to do with either of them as it still won't run with the alrms either in or out.
the car will start and run fine for about 10-20 seconds. then its sorta sputters and dies off. Smelling very rich when it does so. There is fuel getting to the injecters.
Does this sound like it could be to do with the coil. as that has has a join put in the wireing which i made more permanent than a terminal block. and since then it has run.
thanks for any help.
Old Aug 8, 2006 | 12:04 PM
thething84's Avatar
thething84
would be apreciative if someone could give me some insight at all.
Daniel Howard
17
Sep 26, 2015 12:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
marky_g
Sep 12, 2015 04:26 PM
