hesitation??
Old Aug 1, 2006 | 08:39 PM
Bexx's Avatar
Bexx
Default hesitation??
please help people advice needed...
right... as most of you know my car has had a few.... minor niggles lol.
I took her to my mechanic last night who is bloody brilliant and I'd not take the car to anyone other than her, I got a new lamda fitted and on the way home the car was going like the clappers, on the way to work great again... and on the way back from work... for a while...
just on the duel carrage way I was overtaking some cars, had been doing 60ish and put her into 5th... she carried on for a wee while then she suddenly dropped the revs and started to hold back.. then from the exhaust i hear bubububububub BANG, (as if she just dumped unburnt fuel through and it went in the exhaust) she jolts forwards and then carries on as if nothing happened it also sounded like i hit the rev limiter but there is no way in hell i had (no i didnt accidentally put it in 3rd before someone says it lol)..
I had this happen before when the old lamda played up.
i carry on taking it a bit more gentle on her, when i start to get comfortable again i come to a roundabout near my home.. sitting in the traffic for a couple of mins no problem idles fine, then i pull onto the round about 1st gear fine... into 2nd.. she hesitates, then jolts forward then hesitates again then suddenly leaps forwards.. i slap the hazards on but shes fine again...
she has never stalled, i dont drive her hard, i haven't kicked the wotnot out of her and I also have only done up to 80mph in her.
I rang my mechanic and she thinks it may be the plugs and leads, but she wants to try and get some fault code readings from it. I also think personally because the car has been needing a lot of work done and now that shes running better other problems are having chance to show up.
I want to get new plugs, leads, rotor arm (bf said that bit I'm not so sure), oil change and filter and both fuel filters changed. she has already had a new rocker cover gasket, MAF sensor and idle control valve.
can anyone give advice if there is anything else I should look at? or has anyone had anything like this themselves? I'm waiting till later when the roads are quiet before i take her out again.
Old Aug 1, 2006 | 10:23 PM
Bexx's Avatar
Bexx
well now that's totally thrown me...
put Ł20 worth of fuel in, checked all her connectors on the wiring I can see and shes running perfect again, took her the exact same route as when she played up tonight, drove her the same way and she never missed a beat...
freaky car
Old Aug 2, 2006 | 12:15 AM
jon@work's Avatar
jon@work
If the car backfired, then it sounds like an ignition fault. Plugs and leads are a good place to start if the ones fitted are getting on in years. As for the rotor arm - send your boyfriend down to your nearest Ford dealer for one of those.
Old Aug 2, 2006 | 04:59 PM
Bexx's Avatar
Bexx
LOL!
will do
Old Aug 2, 2006 | 06:07 PM
sailorbob's Avatar
sailorbob
Now who's going to be most confused asking about a rotor arm for a zetec?
If your mechanic charges reasonably it's still probably worth getting the code reader on it, intermittent faults very rarely disappear for good.
Old Aug 3, 2006 | 06:21 PM
Bexx's Avatar
Bexx
especially on fords!
i used to work in ford CRC in glasgow till they made us all redundant.
shes running ok just now, but i want to get her back into the garage asap. thansk for the replies folks.
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Bailes1992
Sep 3, 2015 02:17 PM
gchristophi
Aug 31, 2015 10:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
