Problems fitting Greens to my Esc Cos
Old Aug 1, 2006 | 08:18 PM
MCU809's Avatar
MCU809
Default Problems fitting Greens to my Esc Cos
I have just fitted a stage 3 chip to my escort cosworth, with the standard injectors it runs fine but as soon as you put the greens in it appears to pour fuel in so much so that it is washing all the crap out of the exhaust and pouring smoke out. The esc is running a L8 ecu with a MSD chip that came from a 4x4 saph, Any help or advice would be very greatfull.
Old Aug 1, 2006 | 09:16 PM
THE RADMAN's Avatar
THE RADMAN
why have you got an l8 in an esc cossy?
Old Aug 1, 2006 | 10:22 PM
sailorbob's Avatar
sailorbob
Has it got the right map sensor for the chip?
Old Aug 2, 2006 | 10:20 AM
silky16v's Avatar
silky16v
Get on That!
sounds like no 3 bar map sensor and wrong ecu for the car (pretty sure a L8 will work though buy not defo 100%)
Old Aug 2, 2006 | 11:51 AM
cossiegreg1's Avatar
cossiegreg1
what ecu is in an escos?
Old Aug 2, 2006 | 12:07 PM
costina's Avatar
costina
Live long and prosper!!
P8 in a escos L8 in saff 4x4
sounds like wrong map sensor to me, which one do you have 2 bar or standard escos one which is 2.5 bar ?
u need a 3 bar
but why a L8 in escos ??????
Old Aug 2, 2006 | 04:44 PM
MCU809's Avatar
MCU809
I have a 3 bar map sensor fitted. I am using an L8 ecu as I had problems with my P8 and at the time was all that i could get hold of. The L8 has been in the car for about 2 years now with no problems to date.
Old Aug 2, 2006 | 05:11 PM
costina's Avatar
costina
check your Co, and are you running a lambda sensor?
other thing is fuel pressure..
Old Aug 2, 2006 | 06:42 PM
MCU809's Avatar
MCU809
Have tried adjusting the screw on the ecu but with no change, the car is running a lambda sensor, the fuel pressure is fixed on the escort there is no adjustment on the regulator.
Old Aug 2, 2006 | 07:02 PM
Billabong's Avatar
Billabong
Speak to Stu@MSD - the chip may not be suitable for your Escort's spec' - that's aside from the overfuelling issue.
Old Aug 2, 2006 | 07:11 PM
costina's Avatar
costina
Had this symtom on a 4x4 i tuned up turn out the map sensor had water inside
Due to the fact i done the cam belt and drained coolent went on sensor from header tank
took me ages to find out
NEVER ASSUME THAT NEW PARTS ARE OK!!!!!!!!!
Big lesson learnt that day
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
