boost probs
Old Jul 26, 2006 | 08:12 PM
cossie0_4's Avatar
cossie0_4
Default boost probs
i am hahaving probs with boost i can get it to 4psi and it drives lovely try to wind up any more no go. it will get to 6psi with actuator pipe off but no more but then it feels hesitant with driving steady but if pushed hrd dont feel as bad any help apreciated i have just checked boost pipes everything looks ok but the turbo to intercooler pipe just blown off could be i didnt tighten it but sure i did cheers for any help
p.s has anybody heard of turbonetic turbos any good etc
Old Jul 28, 2006 | 09:57 PM
vodoo1's Avatar
vodoo1
Default Re: boost probs
could be a knackered diapfram on your actuator or even a worn cam can do that , happened on a mate of mines rst
Old Jul 31, 2006 | 11:29 AM
SafeChav's Avatar
SafeChav
If you're disconnecting the actuator pipe and only getting 6psi (!!!! brave man trying that) chances are the wastegate is damaged, like cracked or similar.
Check that and for a weak actuator as said
Old Jul 31, 2006 | 10:59 PM
cossie0_4's Avatar
cossie0_4
Default boost probs
thanks for the advice i will try both these ideas and will let you know the result cheers
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
