OFAC fault codes
Old Jul 26, 2006 | 07:43 PM
Avinitlarge's Avatar
Avinitlarge
Default OFAC fault codes
Just checked for fault codes, I have 2
31 - ECM ROM/RAM failure
72 - WCS
I know why the WCS (Wastegate Contol Solonoid) shows up, I havnt got one connected
As for the other, It has baffled me a little, It does it on 2 different ECU's. I thought my original was faulty due to this fault code so I tried another, The fault code is still there
Old Jul 27, 2006 | 06:07 PM
sailorbob's Avatar
sailorbob
Have you got a chip fitted? A poor connection will throw up error 31.
Old Jul 27, 2006 | 07:46 PM
nick series1's Avatar
nick series1
Mine threw up a 31 when i had a slightly dodgy battery !!!
Something like low voltage to the ECM.
1 Thing i've learnt over the past 5 days is EARTH EARTH EARTH EARTH EARTH.
Never underestimate the effects of a slightly dodgy earth. !!
Old Jul 27, 2006 | 10:04 PM
Avinitlarge
Yes it has a chip fitted, Tried two chips and two ECU's and still get the same fault
Old Jul 27, 2006 | 10:39 PM
SafeChav's Avatar
SafeChav
What about without the chip plugged in?
Old Jul 28, 2006 | 08:49 PM
Avinitlarge
And with no chip the fault is gone
Old Jul 29, 2006 | 01:30 PM
SafeChav's Avatar
SafeChav
VOILA!!
Old Jul 29, 2006 | 04:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
The only chips i know of that wont do this are mine. Its a checksum error.
Old Jul 29, 2006 | 08:09 PM
sailorbob's Avatar
sailorbob
I would have said a poor connection can also throw up this error but that's on the assumption that the checksum has been recalculated or the checksum check routine had been disabled. It's poor state of affairs if the chip vendor cannot be bothered to recalculate the checksum, a to you Stu and opposite for the others.
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
