manual boost controller advice.
Old Jul 25, 2006 | 07:33 PM
obie130's Avatar
obie130
Default manual boost controller advice.
firstly hello to all i am a newby.i dont run a ford but a cavalier turbo c20let,and i have a manual boost controller to be fitted to it question i have is can it be fitted in series with the amal valve so i have a little bit safety if something goes wrong ordoes it have to do away with the amal.i also run a courtney pahse 1 chip,15-16psi overboost and 9-10 psi held i have a front mounted intercooler what boost should i set the mbc at ? would 12psi be safe and would i need to adjust actuator.thanks in advance.
Old Jul 28, 2006 | 07:05 PM
TURBO BOI's Avatar
TURBO BOI
remove the amal, best spk to the chaps on here that run lets
www.migweb.co.uk
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
