EFI Conversion and Sierra Pulley problem
Old Jul 22, 2006 | 09:16 PM
MarkN's Avatar
MarkN
Default EFI Conversion and Sierra Pulley problem
Help!!
I'm converting my Mk3 Escort 1.6i to EFi and have got stuck. I'm using a 1.8 Sierra pulley for the CPS which I've had machined and I can't seem to get it to fit. I've released the drivers side engine mount and dropped the engine right down on that side. But once it's dropped the engine has tilted and is too close to the chassis rail to be able to fit the pulley on.
Do you have to release all of the engine mounts and drop the engine that way? I'd rather not do that unless it's absolutely necessary. I'm wondering if I'm having the problem because it's a Mk3 rather than a Mk4 - perhaps I have less clearance.
Does anyone know the answer?
Mark
Old Jul 27, 2006 | 08:39 PM
tsrtrocse's Avatar
tsrtrocse
i have a mk 4 and i had exactly the same problem. i ended up dropping the whole thing out the bottom, putting it on and then lifting it back in. it was easy when you have a engine crane sitting there!!
Old Jul 27, 2006 | 10:38 PM
SafeChav's Avatar
SafeChav
You should be able to fit it as is, i know they are a very tight squeeze, ive never fitted one myself though even though i do have the timing wheel.
You could try gently levering the engine over (lots of rags etc so you dont scratch anything )
Old Jul 28, 2006 | 09:39 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Old Jul 28, 2006 | 04:30 PM
ian r's Avatar
ian r
take the engine mount off and jack it up thats what i did
Old Jul 28, 2006 | 06:57 PM
TURBO BOI's Avatar
TURBO BOI
thats what i did too
i just removed 3 17mm bolts at the rear and remove earth cable to cam cover and jack it up
make sure you support the engine first tho
EoinXR3
Sep 7, 2015 05:44 AM
andyrs1600i
Aug 30, 2015 07:21 PM
Vincereese
Aug 15, 2015 06:24 PM
mpilk
Aug 12, 2015 09:40 PM
Vincereese
Aug 11, 2015 08:44 AM
