RS2000 air con
Old Aug 15, 2004 | 02:12 PM
CJ's Avatar
CJ
Default RS2000 air con
I currently own a 94M RS2000 4x4, The clutch has gone in the compressor and i've been told that the compressor needs to be sent off to be reconditioned. My problem lies in that the same guy doing the job has said that once you take it off the car the engine won't run as its on the same belt. Is this true? and if so is there any way around it?
cheers
CJ
Old Aug 15, 2004 | 05:41 PM
DazC's Avatar
DazC
Its driven off the fan belt so if you remove that, you will get to the end of the road and the car will cut out with a flat battery. I am not sure but the water pump might be driven by the fan belt as well and also the power steering....
The easiest way to do it is get a new one and swap it over...
Old Aug 15, 2004 | 08:10 PM
richm's Avatar
richm
get a drive belt for a non-aircon model
Old Aug 16, 2004 | 01:03 PM
CJ's Avatar
CJ
Unfortunayely Daz i thought of that one but ford said they no longer make them even though i thought they had to up to the end of the 10yr period, cheers for that rich I'll look into it,
Old Sep 9, 2004 | 10:52 PM
blaazer2's Avatar
blaazer2
try a motor factors they should be able to supply a belt the correct size
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
