engine missfire
Old Aug 30, 2004 | 02:47 PM
jonseyrs's Avatar
jonseyrs
Default engine missfire
Engine on bro saph cossie missfires on high boost, after 4000 revs. Changed leads, plugs and hoses. Also have sprayed sensors with wd40 and the problem is still there. Anybody have an idea?
have also tried turning boost down but still no joy
Old Aug 30, 2004 | 03:51 PM
RS500/364's Avatar
RS500/364
GAP ON THE PLUG WHAT 1s DO YOU USE?
CHECK ALL THE TIMING AND BITS YOU CAN
Old Aug 30, 2004 | 04:23 PM
Alloy's Avatar
Alloy
Usually an engine missfiring is associated with timing, so i would check that out and make sure it is running correctly.
Old Sep 1, 2004 | 10:49 PM
vodoo1's Avatar
vodoo1
i had this problem mind you was on a zetec not a yb , it was the throttle position sensor had gone and the air flow meter , and a split in the air flow pipe so was sucking in more air after the sensor , best to get it on a diagnostics thats wot i did , i wa spulling my hair out not knowing wot was wrong because it had been serviced by myself just be4 it played up
Old Sep 2, 2004 | 02:05 PM
wimwerf's Avatar
wimwerf
maybe buy a group a coil.
Old Sep 2, 2004 | 05:55 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Check your coil connections for rust
I also had this problem and the coil connections where rusted and i cleaned them and problem was gone
Old Sep 2, 2004 | 06:44 PM
jonseyrs's Avatar
jonseyrs
It was the spark plugs. thanks
Old Sep 3, 2004 | 06:08 PM
CosRush's Avatar
CosRush
Jon,
Just out of interest, what was wrong the plugs?
Wrong grade, Gaps, Worn....???
Old Sep 4, 2004 | 12:18 PM
jonseyrs's Avatar
jonseyrs
ONE OF THEM WAS DIFFERENT FROM THE REST AND THE GAPS WERE DIFFERENT.
Old Sep 9, 2004 | 09:14 PM
blaazer2's Avatar
blaazer2
does it splutter pop and bang or just miss?
Old Sep 10, 2004 | 06:41 AM
CosRush's Avatar
CosRush
Splutter Pop and Bang....
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
