Tech Question on boost controlers
Old Aug 15, 2004 | 09:42 AM
scooby8272's Avatar
scooby8272
Default Tech Question on boost controlers
When using a boost controller where do you set your actuator ?
Old Aug 17, 2004 | 09:37 PM
Iain's Avatar
Iain
This is definately the blind trying to lead the blind but I think you can leave the actuator on it's original setting and the boost controller controls the additional boost.
I don't know what the pros and cons of raising or lowering the actuator setting would be...
HTH, CheeRS,
Iain
Old Aug 18, 2004 | 10:54 AM
xrsi's Avatar
xrsi
i was told that fitting them u just give the actuator a little preload so it doesnt rattle and then the controller does everything!
Old Aug 18, 2004 | 12:31 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Depends wot boost controller u use.
If using the profec b u can set ur actuator to whatever u want it to be when the unit is switched off. I.e i an going run 1bar actuator when controller is off then low setting 20psi and high setting 25psi when controller is on .just waiting for delivery.
Old Aug 18, 2004 | 08:58 PM
scooby8272's Avatar
scooby8272
Is that right ............
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
