rebuilt cossie engine naturally aspirated
Old Aug 14, 2004 | 06:14 PM
cossieminor's Avatar
cossieminor
Default rebuilt cossie engine naturally aspirated
noisy hydraulic lifters fitted new ones but still noiey but running 10 30 oil is that the problem
Old Aug 14, 2004 | 07:35 PM
yogi's Avatar
yogi
did you replace oil pump
Old Aug 14, 2004 | 08:21 PM
cossieminor
yes ,high pressure one got 80 psi at 3,000 rpm
burtons recon u must change cams and go to solid lifters
Old Aug 17, 2004 | 02:41 PM
whitneyd's Avatar
whitneyd
Did you soak the lifters in oil for 24hrs?
Old Aug 17, 2004 | 06:10 PM
cossieminor
NO, SHOULD I AV AND WOT OIL SHOULD I USE 10 50 OR 10 60 BUT IM NOT RUNNING A TURBO
Old Aug 17, 2004 | 06:14 PM
cossieminor
IM STILL RUNNING IN THE ENGINE IN AT THE (ABOUT 50 MILES SO FAR) BUT THE LIFTERS ARE GETTING QUIETER
Old Aug 17, 2004 | 08:34 PM
edd's Avatar
edd
sometimes takes 100miles but get some thicker oil in it 10/30 is piss water
Old Aug 17, 2004 | 09:06 PM
cossieminor
THANKS 4 EVERYTHING,GOING TO RUN IN A BIT LONGER AND CHANGE OIL TO 10/50 FULLY SYN
MANY THANKS
COSSIEMINOR@YAHOO.CO.UK
Adam-M
Aug 26, 2015 05:53 PM
Gadget
Aug 26, 2015 01:02 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
