relocating battery
Old Jul 15, 2006 | 06:57 PM
mk4gartrac's Avatar
mk4gartrac
Default relocating battery
Has anybody got any ideas on relocating my battery to my boot?
Old Jul 15, 2006 | 07:31 PM
NEWTON's Avatar
NEWTON
put it in a battery box in the boot,run the cable down the side
Old Jul 15, 2006 | 10:56 PM
SafeChav's Avatar
SafeChav
Easy peasy to do, you just need some big ass cable to compensate for and help reduce the voltage drop
Old Jul 16, 2006 | 06:42 AM
mk4gartrac's Avatar
mk4gartrac
i have all that but was wondering about fuses.Weather or not to fuse the cable from the battery and if so what size fuse and how to joing the cables under the bonnet?
Old Jul 16, 2006 | 11:29 AM
SafeChav's Avatar
SafeChav
You would really have to use a circuit breaker, that would need one big ass fuse, unless you are looking at wafers, but a circuit breaker can just be reset
Old Jul 16, 2006 | 04:28 PM
costina's Avatar
costina
Live long and prosper!!
Go to a local auto electrician he will have large crimp tool for batt cable use a round end 8mm one end and 6 mm other bolt to batt and starter also all othere batt + can b bolted to starter + aswell
Old Jul 16, 2006 | 08:46 PM
mk4gartrac's Avatar
mk4gartrac
what size breaker do u think?
Old Jul 17, 2006 | 09:33 AM
SafeChav's Avatar
SafeChav
Depends on the size of your starter motor. You should be able to work out what current rating you need from the Watt figure of the starter
Old Jul 17, 2006 | 03:52 PM
mk4gartrac's Avatar
mk4gartrac
Old Jul 17, 2006 | 05:34 PM
SafeChav's Avatar
SafeChav
I take it you didn't understnad what i wrote?
Old Jul 17, 2006 | 08:56 PM
mk4gartrac's Avatar
mk4gartrac
I do understand it but not sure how to work it out
Old Jul 18, 2006 | 08:22 AM
SafeChav's Avatar
SafeChav
Ohms law, if you've heard of that.
V = I x R
W = I x V
So to calculate the current draw of your starter, the formula re-arranged would be I = W/V
That any clearer?
Old Jul 19, 2006 | 02:36 AM
stevenebm's Avatar
stevenebm
post whore
V = I x R
W = I x V
That any clearer?
in simple terms.divide the wattage by the volts
i.e 120 watts divided by 12 volt is ten amp
Old Jul 19, 2006 | 09:03 AM
SafeChav's Avatar
SafeChav
V = I x R
W = I x V
That any clearer?
Just come storming in after i do the dirty work why dont you
Old Jul 19, 2006 | 03:52 PM
mk4gartrac's Avatar
mk4gartrac
If i can find out the watt figuer of the starter i will work it thanks
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
