oil probs 2wd saph
Old Aug 14, 2004 | 04:07 PM
yogi's Avatar
yogi
Default oil probs 2wd saph
when i drive my car hard oil is coming straight in to the airbox and dripping oil out of the bottom. its also getting splashes into the turbo causing puffs of blue smoke its stage 1 running 15psi and has had a bottom end rebuilt any ways of curing this i have a drilled cam cover should i get a oil breather system would this cure this
Old Aug 18, 2004 | 02:06 PM
Guinnless's Avatar
Guinnless
I'd have a compression check first.
Old Aug 18, 2004 | 08:16 PM
wimwerf's Avatar
wimwerf
are you sure the bottom is rebuild. this could be your piston rings.
Old Aug 19, 2004 | 11:21 AM
cozzie4d's Avatar
cozzie4d
Default piston rings / oil breather
the piston rings sound familiar to me too, when I run to much boost, the same thing happens, the oil comes out of the hose which goes from the engine block (left side) to the airfilter box (or to the separate oil filter when you have a open-air filter). I think an oil breather would work, because the oil which now lands in your airfilterbox, then lands in your shiney mirrortank
Old Aug 19, 2004 | 12:19 PM
Stu @ M Developments's Avatar
PassionFords Creator
Check the oil isnt overfull..
Does it do it mainly after fast cornering?
Old Aug 19, 2004 | 12:22 PM
simon280's Avatar
simon280
Stu's the man - I had exactly the same thing when the idiot in the garage put in too much oil.
Si.
Old Aug 23, 2004 | 07:54 PM
yogi's Avatar
yogi
well i have had new rings everything fitted new piston rings only done 100miles scince rebuild ect and checked oil to much in, also disconnected the oil breather pipe that goes in to air box cut a coca cola bottle 500ml 1 and put the pipe in there drilled a few holes in it for breathing and taped it in place and guess wat hey presto oil catch tank (temp) and not a bit of blue smoke out of zorst also took it for a hard run and checked bottle for level and there was only a little bit in the bottom watery oil so i think a oil breather kits on order should solve this
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
3doorcozmess
Sep 15, 2015 06:06 PM
jc1989rs
Sep 5, 2015 08:09 PM
