cossy managment on S2 (timing)
Old Sep 18, 2003 | 07:26 PM
flashpoint's Avatar
flashpoint
Default cossy managment on S2 (timing)
Hi, does any body know at what point the crank rotation sensor is triggered by the four trigger segments on the crankshaft pulley “ is it on the leading or trailing edge of each of the segments?
And would this be the same for the two trigger segments for the phase sensor?
Any help would be great
Steve
Old Sep 18, 2003 | 07:31 PM
CozzyBrom's Avatar
CozzyBrom
ya have to mark out the rst one as the same as the cozzy one
and the phase senor ya have to heat up the shaft on the cozzy one and turn it round back on the same splines
Old Sep 18, 2003 | 11:33 PM
richm's Avatar
richm
The crank sensor needs to line up with the CENTRE of the pegs at TDC, 90deg, 180deg, and 270deg.
The first phase sensor peg needs to line up with the phase sensor at approximately 45 crank degrees after TDC
Old Sep 19, 2003 | 12:00 PM
flashpoint's Avatar
flashpoint
Thanks guys just what I needed to know,
Rich you say phase is about 45 degrees after TDC, I assume it is not as critical as the crank timing?
Cheers.
Steve.
Old Sep 19, 2003 | 09:00 PM
richm's Avatar
richm
no, the precise phase timing isn't critical, the first phase peg needs to align within the TDC - 90Deg. crank window, 45deg. ATDC is thus the nominal mid point.
Billy_RS
16
Oct 11, 2025 09:41 PM
jay030787
Sep 18, 2015 07:34 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Cameron
14
Aug 9, 2015 06:28 AM
Old ford
Jul 31, 2015 06:50 AM
