Map sensor, where does the earth come from???
Old Aug 13, 2004 | 11:00 AM
CosRush's Avatar
CosRush
Default Map sensor, where does the earth come from???
There is an Earth point on the Map Sensor on one of the 3 mounting holes.
Where does this earth come from?
Is it from the loom? if so, where exactly? in the same part of loom that connects to the map sensor near to the map sensor connector?
Old Aug 13, 2004 | 02:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the map sensor has an earth connection that comes from the ecu loom. that loom earths onto the main loom, and also onto the engine at the throttle cable bracket.
hth?
Old Aug 13, 2004 | 02:52 PM
CosRush's Avatar
CosRush
So where the the loom wires go to the map sensor connector, is there a seperate Earth wire that comes out of the loom next to this connector?
Ive got the Earth wire connection on the throttle from the loom, but the Map sensor has an Earth point on it, so im wondering what goes onto it?
Old Aug 14, 2004 | 12:10 AM
Billabong's Avatar
Billabong
It's earthed at that point through the MAP sensor bracket.
Old Aug 14, 2004 | 04:33 PM
CosRush's Avatar
CosRush
Oh i see, so the bolt holding the map sensor onto the bracket is what earths the map sensor itself?
Old Aug 15, 2004 | 04:58 PM
Billabong's Avatar
Billabong
Yep, there's no seperate earth strap needed there, just the bolt.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
